Murd's 55
flasher cans are normally located under the dash or drivers side kick panel.it make that tick noise when you use your indicators.its a cylindrical type shape out of plastic canister either made of shinny alloy,clear hard plastic and its got 2,3 or 4 prongs similar to a relay but relays are made into a cube form?
Edited by drc_ke20
  • Replies 564
  • Views 200.7k
  • just some extras.   the car has remote central locking, alarm, and atm a mostly broken stereo. it also has the darkest legal tint ect just things to make her look prettier and be more secure =]
They're made all different ways.
The one in my 36 was a rectangle box.
I just fixed the dry solder joints and all was sweet.
i wil have a look today after work. is there a way in which i can tell if it is the flasher can and not the combo switch
Yes Remove the flasher can put a piece of wire between the 2 contacts and the flashers should stay on instead of flashing.
well i can't work out what or where this stupid flasher can is, and now since i was in fiddling with god knows what my fan/aircon has completely died! WTF!
so over this car atm. giving me the shits. first the HU then the diff then the indicators now the god damn air con. stupid pos. i guess she has been very problem free for the past few years, they didnt all have to catch up at once tohu!
It was because she was showing off the fact she has aircon on the cruise. Karma's a bitch ay? :y:
Nah, seriouly. Hope ya get it fixed soon :bash:
alll issues fixed, thank god, found my passenger door central locking died too, wires had like cut in half where the door closes on them! but that was an easy one to fix.
the car is hopefuly gettin some goodies on the way, lets say, it is turning into geek central :y:
Glad you found and fixed all the current problems.
You'll have to pick up the geek central brackets.
well done fixing here,knock on wood no more dramas?
Whats more geeky then a pc? Are you gonna put pocket protectors and pens in everything you can see. And use the shirt material as the trim...Oo.oo. And get some braces as lining for a visor?
What are you getting thats geeky then?
