September 26, 200818 yr comment_277421 Hey Nearly got my licience and ive got a sweet ke70. Originally i was going to build a 4k for it but my bro has 1 in his ke30 and it seems abit gutless. So i just wanted to no what motor i should put init and how much they would cost. Cheers brandon Report
September 26, 200818 yr comment_277422 4age price varies around 1400 for a complete conversion if ur doing it urself Report
September 26, 200818 yr comment_277426 Where can you get complete setup from? pref already converted for rwd. Report
September 26, 200818 yr comment_277427 Drive it for the first year with a 4K. Then upgrade. Ditto - then drop in a 5k or a 7k, heaps easier and cheaper. $100 to $500 for a 5k depending on the deal you get. Report
September 26, 200818 yr Author comment_277428 cheers. If anyone has done a 4age conversion in a ke70 let us no Cheers Report
September 26, 200818 yr Author comment_277429 i race junior sedans at the moment so i no alot about 3ks and 4ks. My brother was telling me that i should just build a 3k because they seem to rev harder. What do you guys think would be better? 3k or 4k? Report
September 26, 200818 yr comment_277431 i race junior sedans at the moment so i no alot about 3ks and 4ks. My brother was telling me that i should just build a 3k because they seem to rev harder. What do you guys think would be better? 3k or 4k? Read in the FAQ about how to make a tuff k motor :yes: Report
September 26, 200818 yr Author comment_277434 i no what to do to make it go hard but i just need to no whether to build a 3k of 4k. I would bore the block to 40 or 60 thou. Get a cam from waggot. do the head. and just clean it up Report
September 26, 200818 yr comment_277437 i no what to do to make it go hard but i just need to no whether to build a 3k of 4k. I would bore the block to 40 or 60 thou. Get a cam from waggot. do the head. and just clean it up Seems you know what you are doing. I prefer the 4a but any k motor can be tuned to reasonable specs. Got any P plate restrictions where you are? Report
September 26, 200818 yr comment_277447 personally i rekon 4age bit later on once you have ur licence for a lil while the money ur gonna spend on a 1.2 or a 1.3 they might rev but they don't go real hard... i rekon if ya gonna do it properly do it the first time... but thats what i rekon good luck with ur decision. johnnyt Report
September 26, 200818 yr comment_277462 i rekon just drive it till you learn, you will know when you need more power Report
September 26, 200818 yr comment_277468 I'm in perth but as far as i no there isnt any. Yeah, no restrictions on P platers here outside of what's plain illegal from an engineering point of view. here's something to try... get a 3K and 4K... swap the heads over. Run the 4K with newly found higher compression ratio (and obligatory cam) on Premium and see how you like it. Or if you have the skills, take your 3K with 4K head (lower compression) and turbo/supercharge it. run 7-10psi and enjoy. EDIT: http://www.rollaclub.com/board/?showtopic=23812 Turbo kit FTW!!! Edited September 26, 200818 yr by white_sandshoe Report
September 26, 200818 yr comment_277482 Drive it for the first year with a 4K. Then upgrade. amen, or better yet, build another car while u drive this one for a while, the experience of pushing a slow car to its limit and beyond is one that should not be looked upon as pointless, teaches you alot about driving a car hard while staying a bit safer, as when shit goes bad, theres less go fasts happening so you have more time to react. then you push harder and harder, then you get more power, and start at the beginning again :yes: Report
