October 13, 200818 yr comment_281215 hi guys. was just after some information on what engines are legally allowed to be engineered in a ke30 in victoria. iv been searching around on youtube, and ive seen some v8s and v6s in ke30s, but don't know what is legal. thanks Report
October 13, 200818 yr comment_281339 hi guys. was just after some information on what engines are legally allowed to be engineered in a ke30 in victoria.iv been searching around on youtube, and ive seen some v8s and v6s in ke30s, but don't know what is legal. thanks Maybe if you did your searching somewhere more appropriate, like the VicRoads website, you'd find all the answers you need. Or if you didn't find the answers, you'd find who to contact to get said answers. Report
October 22, 200818 yr comment_283706 Doubt its legal plus the cars on youtube are either illegal or they are spend shit loads of money to make it legal but i doubt it very much Report
October 24, 200818 yr comment_284310 or they got club rego or not there every day car. so they sneak it around the block Report
October 26, 200818 yr comment_284712 Just cos you seen 'em on youtube, doesn't mean they're legal. Edited October 26, 200818 yr by decoop Report
November 21, 200817 yr comment_291810 Anywhos, Go to the local roads authority website, lookup the restrictions on size of motor VS weight and then you will no how big you can go Report
November 21, 200817 yr comment_291975 ke30 weighs 890kg X 2.5 for turbo = 2225cc x3 for non turbo 2670cc i think thats national now but check your state Report
November 21, 200817 yr comment_291984 Mate, don't bullshit the whole Rollaclub community that you have been and searched for the information you're after. :) There's info on the FAQ for Victorian cars: CLICK HERE There's a KE20 kicking around Melbourne fully engineered with a Windsor 289 (It had a blower at one point too). Report
November 22, 200817 yr comment_291996 Mate, don't bullshit the whole Rollaclub community that you have been and searched for the information you're after. :) There's info on the FAQ for Victorian cars: CLICK HERE There's a KE20 kicking around Melbourne fully engineered with a Windsor 289 (It had a blower at one point too). What was legal and what is legal now are 2 seperate things, there,s a lot of 13bt engineered cars that were done years ago but you,ve got no hope now, as i said check with your state but thems the rules Report
September 28, 200917 yr comment_377320 What was legal and what is legal now are 2 seperate things, there,s a lot of 13bt engineered cars that were done years ago but you,ve got no hope now, as i said check with your state but thems the rules Hate to rehash an old post but......... I just rang up an engineer here in Vic who said he will approve ANY of the Jap import engines for my AE71 as long as: - all the components are stock - factory ECU - suspension and brakes upgraded to suit - there's no cutting of chassis rails, firewall etc. He said that because all the jap import engines have a stock power output, in theory, of 206kw the power to weoght ratio is within acceptable limits. Hope this helps the Vic modifiers on this forum. Report
September 28, 200917 yr comment_377404 Hate to rehash an old post but......... I just rang up an engineer here in Vic who said he will approve ANY of the Jap import engines for my AE71 as long as: - all the components are stock - factory ECU - suspension and brakes upgraded to suit - there's no cutting of chassis rails, firewall etc. He said that because all the jap import engines have a stock power output, in theory, of 206kw the power to weoght ratio is within acceptable limits. Hope this helps the Vic modifiers on this forum. Whats the name of the engineer and the business he/she trades under? Report
September 28, 200917 yr comment_377454 Whats the name of the engineer and the business he/she trades under? His name is Gary Le and I got his name from the VASS list on the Vicroads website. He is located in the Wantirna or Dandenong, I left the list at work so i'm going from memory. What information he didn't give me was what the maximum allowable power to weight ratio is. He also recommended that I get a second opinion but I didn't bother because he'll be the one approving my engine mod, hopefully. Report
September 29, 200917 yr comment_377504 Yeh, it's generalised rules of thumb like this that kick the rumour mill into top gear. Look, I've got no doubt that you can get it done. But to "get any motor" into an AE71 will likely need custom mounts making it a bit more difficult. If it's coming from a VASS engineer, hold him to it when you take your car in for certain. The biggest concerns mine had with my poobird was the brake test and the emissions, which get tough after 87 (on the chassis that is) If I recall correctly. Report
October 1, 200917 yr comment_378274 His name is Gary Le and I got his name from the VASS list on the Vicroads website.He is located in the Wantirna or Dandenong, I left the list at work so i'm going from memory. What information he didn't give me was what the maximum allowable power to weight ratio is. He also recommended that I get a second opinion but I didn't bother because he'll be the one approving my engine mod, hopefully. The power to weight ratio does come into in the equation in some circumstances i believe. However, the main factor is weight v's capacity of the replacement engine. Make an appointment with the engineer, and get everything in writing. He will file it and bring it out when it comes time for your inspection. The time from my consultation to inspection was approx 2 years. It was handy knowing that i had guidlines to work to, and there wouldnt be any issues if i played by his rules. The following link is a copy of what my engineer gave me as proof of the guidlines he works to for approving replacement engines. CLICK Report
