kickn5k Posted May 8, 2012 Report Share Posted May 8, 2012 More goodies arrived today, swapping out the steel nuts that hold the tail lights in with Alloy nyloc nuts. Also changing the bolts that hold the door panels on, to black alloy dome cap screws, they'll look better with the carbon fibre and you won't catch yourself on the bolt. Do you source these through Tristan at redline motorcycles in Vic?? Looking good guys keep up the good work. Thanks again for the info on the 4age head studs(was a while ago). The new engine I screwed together for him just made 302rwkw on 35psi of boost. I might also add it loves it!!! Stu. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted May 8, 2012 Author Report Share Posted May 8, 2012 http://www.probolt-australia.com/ is the place i get my bolts from Stu. They come out of the Uk. 35psi, :o Great effort!! Your welcome with the info, hope it help ya. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted May 12, 2012 Author Report Share Posted May 12, 2012 Good day today. Windscreen is back in and sealed up nicely, got the inside of the boot all painted, along with the boot and mould for the lower panel. Hopefully glass up the rear panel tomorrow. Fuel tank, tail ights, wiring and all the brackets installed into the boot as well. Trying to get the car onto the Dyno this week. We'll be picking up the new tyres next saturday, we managed to distroy 6 tyres in only 40km's at Hirstglen. Quote Link to comment Share on other sites More sharing options...
KE70slider Posted May 13, 2012 Report Share Posted May 13, 2012 Have you tried the Yokohama ao35's they seen to keep gripping even when tread depth is low Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted May 14, 2012 Author Report Share Posted May 14, 2012 Yip. They (Yoko's) had good straight line traction but not a lot of sideways traction. The problem isn't the tyres, the road surface at Hirstglen is really hard on tyres, everyone was suffering from the same problem. This happen the first time we went there as well. Hoping to get some hards for the next round and see if they help. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted May 28, 2012 Author Report Share Posted May 28, 2012 Just back from rally QLD, which has given us a little motivation. Tony and myself were up there servicing for a couple of teams. Also got to see my mates Group B Celica in the flesh. Ran the car on the dyno tonight to see if we have sort out our venting issues, it appears we have. http://youtu.be/-5qMdPP8B9s Quote Link to comment Share on other sites More sharing options...
kickn5k Posted May 28, 2012 Report Share Posted May 28, 2012 Also got to see my mates Group B Celica in the flesh. Ran the car on the dyno tonight to see if we have sort out our venting issues, it appears we have. That celica is sick!! On your "venting" issue are you filling the catch can? If so we've had the same issues with my mates 4agte(and a customers 4age). It has never done it on the dyno or when it's cruising, so it's not blow by. So we've now moved onto changing the catch can pick up point from the rear of the rocker covers to the middle to try and stop it. I believe with his car as it's got so much power/g-force and at big rpm the oil pumps on these are probably a little too efficient, it just pumps it out the back. Hopefully changing this to the middle should help. Keep you posted on results!!! Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted May 28, 2012 Report Share Posted May 28, 2012 Nice, what was the fix in the end? Quote Link to comment Share on other sites More sharing options...
snot35 Posted May 28, 2012 Report Share Posted May 28, 2012 Wow, that Celica has come a long way! It's looking the goods! How much on the dyno, or is that top secret? :) Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted May 29, 2012 Author Report Share Posted May 29, 2012 The fix was related to oil pressure, 4age's DON'T need the oil pressure relief increased. HP?? i might keep that one to myself at the moment, i may share it when we finish developing the engine. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted June 18, 2012 Author Report Share Posted June 18, 2012 Didn't really expect to see this on the entry list for this weekends rally sprint. Quote Link to comment Share on other sites More sharing options...
snot35 Posted June 18, 2012 Report Share Posted June 18, 2012 Does that mean you won? :) Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted June 25, 2012 Author Report Share Posted June 25, 2012 Here's a little video from the weekend. http://youtu.be/Z_lznJZD8Sk Quote Link to comment Share on other sites More sharing options...
rob323 Posted July 1, 2012 Report Share Posted July 1, 2012 Sorry for the shaky camera work, it was bloody freezing up on that hill. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted July 8, 2012 Author Report Share Posted July 8, 2012 No worries Rob, it was bloody cold out there. So we spent a little time this weekend going through the car after the last event showed a few problems. It appears there was a bent ball joint that we didn't know about, now fixed, but this also gave us the chance to have a look at the bump steer. Wasn't as bad as we had thought but there is room for improvement, which we'll get around to soon. So with the front end apart we've given the car new wheel bearings, greased all the brake slides,inner syphericals and blead the brakes. Tony removed the front bumper for repair after a little nudge into a bank, and straightened out the bar bracket. We have a rally in a couple of weeks, so it'll be interesting to see if we can finally finish one in the new car. fingers crossed.... Quote Link to comment Share on other sites More sharing options...
