November 15, 201015 yr comment_482453 ok say if i was to be silly and randomly bolt on any random turbo to my 3tc what would be the best option regarding the turbo i should use do u have to run a computer thing to run and what happens when u don't :D Report
November 15, 201015 yr comment_482465 check out these 2 websites there into there 3t's http://www.paradiser...com/headers.htm and http://brdracing.com/ and you should be able to run a blow through carb setup. Edited November 15, 201015 yr by 19914afc Report
November 16, 201015 yr comment_482493 Or you could hunt up the turbo exhaust manifold from the 3t-gtue. Couldn't one be made up cheaper then that on Paradise ? Induction - i'd be leaning towards EFI but apart from that a carby blow-through setup, that way you could run a small intercooler. There is the option of a carby draw-through but apart from the on-throttle/off-throttle lag time cause of the location of the carby, fuel will also be drawn through the turbo. The only real drawback on the blow-through setup is having to mod or "box" the carby. I don't really know much about the turbo thing itself but i'd be looking towards something from a similar sized motor. Report
November 16, 201015 yr Author comment_482638 hmmmm so what would happen if u ran the turbo without a boost controller or ecu for ??????? Report
November 16, 201015 yr Author comment_482649 realy high temprtures ect??? is there like any other way of controling a turbo besides computer ????? s Report
November 16, 201015 yr comment_482653 grab an sc14 or sc12 superchager run a suck through set up with a carby no computer Report
November 16, 201015 yr Author comment_482655 could get me a digram of how to put one on a 3tc if so ure a legend Report
November 16, 201015 yr comment_482663 my mate made his own turbo mani for a stock 2tc and had a really massively jetted webber on it and made a custom carby hat for it, and hung a vl turbo turbo off the side, it went like a cut snake Report
November 17, 201015 yr comment_482775 Danger to manifold. Shutup. *slams laptop on passenger seat* Report
November 17, 201015 yr comment_482781 There was a photo of my laptop on my passenger seat with 'danger to manifold' on the screen, lost it with my hdd crash, will get another one. Report
November 17, 201015 yr Author comment_482814 but is there any other ways to run a turbo besides computer :blinks: Report
November 17, 201015 yr comment_482815 realy high temprtures ect??? is there like any other way of controling a turbo besides computer ????? s L O L qft I suggest you go and wiki search on how a waste gate works buddy. And ah.... you don't need a computer. Report
