You've pictured a ke30/55 4 speed there, so you'll have to cut a hole for the shifter. Like you said a ke70 box will line up with the auto shifter hole.
Oh and you can't use a 5k head on a 4k as it'll give you something stupid like 14:1 compression. 3k head will up the CR on a 4k acceptable though.
Yeh, thought that it would need cutting to fit a ke70 box but didnt realise that the auto box was in the right spot, least the ke70 5spd's are more common to find!
Ah what i meant was 4k head on 5k block, but we have found a 5k head so will be doing a complete 5k.
well, putting the 5k together, still need 4 pushrods that are 141.5mm ball and cup, cos we don't have the 5k rocker gear, so if anybody has any that size or knows where to get some, let me know if you can ;) . Gonna hopefully clean the rest of the bay and put in the engine/block and gearbox on sunday, rego soon and then putting on the superchargerrrrr !!
Edited by haydoss
Got the 5K and gearbox in today, just gotta find 2 more pushrods from an A10/Datsun 1000 engine to complete it.
Made an adaptor to put the pulley from the crank and the supercharger to spin together
Once we get some pushrods, hopefully get the supercharger in and ready to go :D
Finished putting the engine together, got it running finally :) sounds a bit like a truck just having it run through the extractors. Getting started on the supercharger sometime very soon :)
You gonna run it off a carby or EFI?
