The fundamentals are good... Engine would comfortably trounce anything A or K powered...
But my god... Those wheels, dat paint.
Edited by 7shades
  • Upvote 1
i don't think its a real race car, look at that bolt in cage. I don't think cams allows bolt in cages?
might look ok with bettter wheels, i don't mind the paint for a race car. gotta stand out eh. though maybe only have 1 colour change, not 4.
Sure do:
http://www.camsmanual.com.au/pdf/10_gen_req/GQ11_2012_Schedule_J_Q411.pdf
18.2 Mounting Points of the Front, Main and Lateral Rollbars or Lateral Half-Rollbars:
(a) Each mounting point shall include a mounting foot consisting of a plate at least 3mm thick.
Each mounting foot shall be attached by at least three bolts to a steel reinforcement plate at least 3mm
thick and of at least 120cm2
area which is welded to the bodyshell. Where attached by bolts, the angle between
any two bolts shall not be less than 60° (measured from the tube axis at the level of the mounting foot
circumference – Drawing J-60).
You have to weld reinforcing plates to the chassis but its still a bolt in cage.
not sure exactly what it is, but i know its getting a rotary and its going to be some form of racecar.....the wheels are 4x114 and 13x8 steelies....mad dish ;) the white one next to it is an rx2 or 3 i think? the guy that runs the shop is matt the mad rotary man....also the one who owns that clean lil ke10 i posted up earlier on in the year
