November 12, 200917 yr comment_390753 hey mate. i gota a question for u. maybe u would know. nobody else does. i got a ke70 with 4 age and so on. but its got a problem. it has no spark. it has power comin to the coil, power going from the coil to the dizzy but no spark comin out of the dizzy and the coil igniter works too. do these motors have dizzy problems or could it be an ecu? maybe it could b something else that u can think of. thanks 4 reading anyways. Edited November 12, 200917 yr by TARAKAN Report
November 24, 200916 yr comment_393334 thanks heaps for this page. a few of the links don't seem to work... all good tho. Ill bookmark this for future reference. More worried about getting mine road legal at the moment... Report
October 23, 201016 yr comment_477612 anyone have a ke70 wiring diagram? i'm stuck with my 4age into ke70 build atm Report
February 19, 201115 yr comment_504297 hey I found a 4age from a wrecked ae92 with k50 gearbox. for only about 600 bucks would that be alright to change to rear wheel drive and put it in a ke70. what else needs to be done? Report
February 19, 201115 yr comment_504315 if it's from AE92 you will need to cut and shut the intake manifold or get a rwd intake manifold with an adapter plate. you will also need to install a spigpot bearing into the crank, the wiring loom will have to be heavily modified as if is for fwd instead of rwd (you could just pay someone to do this if your not confident). You will need to source rwd engine mounts from an ae71 or ae86, then everything else in this engine conversion is straight foward, you will need a pedal box from an ae71/ae86 aswell. it's all writen in the post on the front page. Report
April 15, 201115 yr comment_517331 going to be putting 4age into my ke70 soon (hopefully next weekend). have ae71 pedal box,crossmembers comin. just have a question for some people who have done it before. what sort of fuel systems have you used? is there a suitable external efi fuel pump to use without a surge tank or won't they work. trying to do it as cheap as possible. was thinkin of vl style pump. any info would be much appreciated. thanks guys. Report
April 17, 201115 yr comment_517709 going to be putting 4age into my ke70 soon (hopefully next weekend). have ae71 pedal box,crossmembers comin. just have a question for some people who have done it before. what sort of fuel systems have you used? is there a suitable external efi fuel pump to use without a surge tank or won't they work. trying to do it as cheap as possible. was thinkin of vl style pump. any info would be much appreciated. thanks guys. Hey mate, the VL pump on its own (no lift pump or surge tank)will work fine, but don't run your tank down too low. I have used just a VL pump in two of my ke70s so far and it works. Report
April 17, 201115 yr comment_517814 yep it works....but its not ideal. and it makes a heck of a noise. (i too ran it for a few months, before putting in my surge tank) VL's have a lift pump that works with the high pressure pump, high pressure pumps do not like sucking fuel at all and i belive will eventually fail if asked to suck fuel for too long. http://www.rollaclub.com/faq/index.php?title=Tech:Engine/A_Series/Installing_EFI_Lifter_Pump_into_AE86_Fuel_Tank i did this on my car, works brilliantly. Report
April 26, 201115 yr comment_519592 what i've done that i hope will work is basically what you've done with that lift pump but i've used an intank pump from bout 93ish corolla. had the pump layin round so if it works it's cost me nothin. :yes: Report
June 21, 201115 yr comment_534033 http://www.rollaclub.com/board/topic/29506-20-valve-into-ae71ae86ke70/ just thought id add this very very good thread :) Report
August 25, 201115 yr comment_549115 TEDDY'S NOOB GUIDE NO #0052 4AGE into RWD KE70 / AE71 / *E7* Conversion Notes Hey All. There's not a day that goes by, when someone ask's *How do i put a 4age into an *e7* ! Basically, i keep pm'ing people about it and kindly showing them where to go, but its getting a bit rediculious. So, here i present to you all the links i know off, that can help you out with your conversion. Its almost a copy from the same thing i made at rollaclub, but more things have poped up since. So, its a revised list as such. Please read it, because there is **alot** of data in there. Basically from now on, any topics *how do i install a 4age into my.. etc* will be trashed, and a PM sent to the member with a link to this page. Please remember, IF you do have a technical question or a specific thing your stuck on; we will happily help you out. Its not so much we don't like trying to help people, Generally i know for one i don't want to go to www.ke70.com - technical and see 20 different 4age into ke70 topics, that all really have what this 1 page has on it, as a general starter type guide... Over the Internet, there are sooo many threads that tell people how to put a 4age into a Ae86 / Ke70 / Ae71 - they are all pretty much the same in theory. Sure, theres heaps of different 4age's over the ages, different rib'd blocks, heads, even displacements as well as bolt on's to make it no longer N/A, but its all the SMALL details that make the BIG difference. This is where a sharp eye, and brain cells come in handy. For all of you metho lovers, you'll need some concentration and focus on this topic, so piss off & get help. So, now we have covered that, be prepared to spend anything from $3000 upto $10,000, depending on what you want, the quality you want, and how you want it done. Before you go ANY further, answer these few questions for your self.... 1) WHY do you want a 4age into your Ke70 / Ae71 ? 2) What is the car going to be used for ? - Street or off road 3) Legalities involved in your state 4) Budget you have 5) how much experience you have After you have put some brain splatter onto paper for those 5 questions, keep reading down... First up, Read all of what i have to post, seriously, then come back with what you don't know, and we can help fill in the blanks. 1) All About the 4age Motor - Find out which 4age you have purchased 2) 4age to RWD application -> Read it and understand it 3) 4AG - ZE into Ae86 - more info on the topic, someone Else's views on how it works - READ IT ALL 4) 4AGE world - make sure you take close note of whats on here, a VERY good place 5) The Witzl's guide to installing a FWD 4A-GE into RWD corolla - Toymods 6) 4A-GZE Comparison, Specs and Differences of all versions - Toymods 7) Rollaclub Guide on RWD'ing a 4age 8) Rollaclub Toyota Info - Everything from A motor rleated to K motor related 9) Very usefull other ae86 club 10) People that have done / doing the conversion - TWizl - Funny Guy, usually not that kind to Noobs asking him questions, but he knows his stuff. - IRallys Ae71 - the car is no longer around, but its memory lives on. This dude knows what hes on about - Jasons Ae71 Project - again, another great example - check for his updated car on rollaclub somewhere - and finally, the conversion I'm doing with a friend, 4AGZE into Ae71 ! yes I'm still learning, but i like to research first :lol: - Mumblez's 4age into his Ke70 - Turbo Rollers 4age into his Ke70 - Trav's 20V into his Ae71 - Feeling like some turbo 4ac action? worth a read in itself :) - another 4age into ke70 - My Personal Hairy lesbian slave, Des - His Ke70 4agze conversion :y: Other Usefull Data - How to read Toyota Motor Codes - Surge Tanks and EFI systems explained - Toymods - Toyota Diff Codes - Toyota Gearbox Codes - Growing Topic on Toyota Drive line Data - Ke70/Ae71/Te71/Ae86 Similarities & Differences AND LAST OF ALL! OMFG the source of all 4age information SO ! Now that you have been given all that is needed, go away and read up all of that, hell, take a week to read it all, theres a farkton of info there, but actually UNDERSTAND IT. Please don't come back asking dumb questions, when most of it is there. Eg. what cross member do i use... We are happy to help, but we are not happy to hold yo ass and feed you at the same time. Please DO ask technical questions that you are stuck on, then we will happily help you out. :) I hope that helps, and hell, we need to make this a sticky! Ted The thread was really helpfull thanks for shraing the thread. Report
August 29, 201115 yr comment_549964 any one selling or know any one selling 4age motor and gear box to go into a ke70, I'm very interested i can't find them anywhere i live in sydney thanks Report
November 23, 201114 yr comment_567652 ok now i know y somone gos oh no..... wen i posted i have a 4age in my ae71.... but i need the car wired up it use to run but some dill choped shit out of loom so under the bonnet is a mess. all I'm relly after is somone in the know how to wire my car up or a good shop to do it for me I'm in condobolin nsw about 6 hrs from sydney but I'm relly keen! in next munth or so i hope to have $1500 to $2500 so if i can not get somone to sorted it on a stock ecu i will go stand alone ecu any help or info please wood be relly good thanks regards doug Report
March 23, 201214 yr comment_592110 Should this and LittleRed's 4AGE to xE7x thread be pinned up in the KE70.com section? Or no? Report
May 12, 201214 yr comment_603460 is ae86 gearbox crossmember direct bolt into ae71 and you just use some washers to lift the hieght of the box? Report
