HEKTIC Posted September 10, 2006 Report Share Posted September 10, 2006 (edited) i know in tassie that if you an n12 exa or n12 et (i asume it would be the same for all cars) you can't get insurance for your wheels if they are any bigger than 16's. i think it has to do with the standard size wheels and you can increase them by 3" or something like that, so I'm guessing that its not illegal just no insurance if they get stolen Edited September 10, 2006 by HEKTIC Link to comment Share on other sites More sharing options...
NickZ Posted September 10, 2006 Author Report Share Posted September 10, 2006 No they will not rego this car with 17" Tasmanian regulations only allow 2" above standard, 13" standard so 15" is the biggest. Ill have standard 13" wheels on it, i will be using standard 13" with white walls and it will be lowered heaps. The exahust is standard, when i put the v6 in ill be using bigger but I'm going to modify a standard muffler at the rear. so back on it will look like a 1.5" out. but the bigger exahust will dump out the bottom of the modified muffler Link to comment Share on other sites More sharing options...
Rolla__Boy Posted September 10, 2006 Report Share Posted September 10, 2006 haha sleeper!! Nice In Canberra you can only go one inch bigger, so 14's are it Link to comment Share on other sites More sharing options...
NickZ Posted October 2, 2006 Author Report Share Posted October 2, 2006 (edited) Hmmmmmm my Port-A-Walls arrived today, If you don't know what they are, its a rubber inlay fitted to the rim and is held on by the bead of the tire Shame the rest of the car looks like crap. Edited February 21, 2007 by NickZ Link to comment Share on other sites More sharing options...
Rolla__Boy Posted October 2, 2006 Report Share Posted October 2, 2006 :jamie: Look at the massive line of cars you have :P Link to comment Share on other sites More sharing options...
NickZ Posted October 2, 2006 Author Report Share Posted October 2, 2006 (edited) Modified the Xmember to fit the Commodore engine mounts Engine now all bolted up, most things fit, but i did this without the bellhousing so i hope it all fits. This is where i wanted the engine to sit. so if the bellhousing doesnt fit ill modify the firewall and tunnel till it does :jamie: the drivers side exhaust manifold just needs to be hit with a hammer to make a dent and it will clear the steering box easy, the other exhaust needs one quick cut and shut to clear the steering on the other side. Castlemaine Rod Shop are supplying the bellhousing. It will take the supra clutch slave,fork,thrust bearing and carrier. I use the supra clutch plate and the commodore pressure plate, can't get any easier than that. Exhaust,rear xmember,tail shaft, wiring and water works are next weekends jobs. I'm going to miss the drag meet nextweekend but it will be ready for the next Edited February 21, 2007 by NickZ Link to comment Share on other sites More sharing options...
hotmr2 Posted October 2, 2006 Report Share Posted October 2, 2006 i really like ur port a wall tyres they look so good. i will get myself when i find a ke35 or 55 car very soon. 1 Link to comment Share on other sites More sharing options...
Brendo Posted October 9, 2006 Report Share Posted October 9, 2006 seen this car when i was at nick's on the weekend, from the sound of his plans its gonna be the biggest sleeper in tassie i reckon... can't wait to see it going cheers Brendan Link to comment Share on other sites More sharing options...
tom210 Posted October 12, 2006 Report Share Posted October 12, 2006 yeah went and had a look today.. very cool.. but not as cool as it will be.. lol Link to comment Share on other sites More sharing options...
NickZ Posted October 13, 2006 Author Report Share Posted October 13, 2006 engine and gearbox are in, got the engine in the rightplace first time and even the tail shaft is standard length and using the supra rear xmember and it bolts to the original mounting holes. The bellhousing was a worry when it turned up as i thought it would never fit, but a few taps with the large hammer and there is no problem I bought a new pressure plate for ebay for $31.40 delivered to my door. Only things left is the clutch master cylinder and exhaust, one manifold is fitted, i still have a clearence problem with the drivers side with the steering box that ill fix at the weekend. then bolt in everything else like the radator and i hope by the end of the weekend it willbe going. I thought i had got the tail shaft yoke sortedout, but no, was the wrong one, you ask the wreckers for a W5x tail shaft and i got something from a 1980 corona wagon, not sure what the hell that gearbox is. Link to comment Share on other sites More sharing options...
demuire Posted October 13, 2006 Report Share Posted October 13, 2006 I once had a 1980 Corona with a 21RC in it, I think it had a W55? Link to comment Share on other sites More sharing options...
NickZ Posted October 13, 2006 Author Report Share Posted October 13, 2006 thats what i thought they where W boxes, but i do know mine is a w58 and the tail shaft from the corona wagon must have a bigger output shaft as this one is sloppy and wont go very far in. I'm hoping by tomorrow afternoon ill have something, but on the upside of it, the uni joint was the same as the one in the ke tail shaft, so i hope most models use the same and ill just have to change the yoke as the tailshaft is the right length. Link to comment Share on other sites More sharing options...
NickZ Posted October 14, 2006 Author Report Share Posted October 14, 2006 (edited) Things i did today. header now clears the steering box. this is how the bellhousing clears the tunnel. Rear xmember location, still needs a little mod. Fitted with the new commodore rear spring in the front for standard right height. Edited February 21, 2007 by NickZ Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 14, 2006 Report Share Posted October 14, 2006 Woah! Not much clearance around that steering box, I see what you mean now.. Looks like its coming along nicely. Link to comment Share on other sites More sharing options...
NickZ Posted October 17, 2006 Author Report Share Posted October 17, 2006 Something i learned today commodores there are two starter motors 1 for manual and 1 for auto, The auto one is like a corolla one but the manual one had a reduction drive and is huge. Well mine being manual the starter is huge and doesnt fit between the engine mount and the bellhousing and the engine was too low so the xmember was in the way. ive moved the engine mount on the xmember further forward and lifted the engine. but it cost me another day. i should have checked before Link to comment Share on other sites More sharing options...
