Hey Guys
As I'm not making AJD I thought I might as-well put up a thread :P
Have been a bit absent from the scene last year or so, sold my KE70 mid 09, bought a T18, sold that, bought a 5K KE70, swapped that for nickyboys KE30, sold that to greenmac80 and now driving a 95 Hiace haha.
So quick summary of the history of my KE25:
Basically it was a Adelaide Hills car, from Inglewood/Paracombe.
Found by Mattie and Chris while doing a hills run. Old guy had it sitting out front for sale. This was start of 2007. I bought it mid 07.
Car had been off the road for (now) 19 years.
Here is a link to my old thread when I first got it: http://www.rollaclub.com/board/index.php?showtopic=14164
Anyways that's all in the past, 2 years on and after being Patient and saving money and buying/collecting bits and pieces I finally found the time to fix it up properly.
Told dad get your Karmen Ghia out the shed. He was more then happy to re-live his days of fixing cars, HQ Monaro's, VW's, RT140 Coronas (he bought and sold) and RA28 Celica's etc etc.
So basically got it in the shed, stripped the front end as that needed the most attention. Dad got me sanding so I had started sanding the car down.
This made me become familiar with the car and find all the spots that needed attention.
Had been in a previous accident (looks like kangaroo) and the front passenger radiator support was mangled. It had been repaired but very poorly done.
So we got it as best as we could, thanks to ke30dude for the replacement panel off his KE20, was a bit different but everything lines up so can't complain.
After we had done that. I cleaned it all up as best as I could, grinded back the welds, put couple skims of bog in the engine bay, removed battery tray, did a lot of panel beating, shaped everything best I could.
Then prepped engine bay and sprayed some Hi-fill primer to fill in all the slight low spots etc
Dad found me some body deadner he used to use, in the shed, tested it and it was still good so did inside the front wheel wells. Looks a lot better.
Then after some minor repairs and rust treatment on the body we got it looking pretty straight. After the hard work of sanding and feathering in all the bear metal patches we got the compressor and hit it with its first stage of Hi-fill primer and guide coat.
Then blocked it back sometime later and hit it with another coat of fresh Hi-fill primer and guide coat yesterday night.
So this is what I am up to at the moment.
At this rate ill have it painted in the next month or so.
We have started repairing my front apron, guards and bonnet, all of which have minimal rust :( and are pretty straight already... must have been replaced at some stage in the 80s lol
ok so here are my plans:
Make/Model:
1974 Toyota KE25 Corolla 1200 Coupe Deluxe
Exterior:
Will be painting an original colour (none of this fancy crap), undecided but might paint same colour or white. Need paint code as I'm not sure if this is D3??? It looks a lot more yellowy and D3 looks more darker
JDM Fender Mirrors
14" SSR MK2s with gold centers are the wheels I'm going to get for it
Engine:
Will be doing an engine conversion later on down the track (one thing at a time)
For time being have a 4K with K50 for cruising
Brakes and Suspension:
ADM AE86 Struts and Brakes with yet to be decided brake master cylinder upgrade
Will work out aftermarket springs and shocks later on
Have Brand New PS Arms
All new utherane bushes thanks to Pedders prospect! Top guys!
All new idler arm, pitman arm, tie rods and ball-joints
Fully powder coated LCA's, swaybar, x-member, castor rods, sump guard etc etc
Also will upgrade my leaf springs to match the front upgrade
Interior:
Completely original apart from Nardi steering wheel and JDM Tacho Dash Cluster
so there you have it. ;) any input would be great :blush:
Want to give a big THANKS to the following people: SLO-030, greenmac80, ke30dude, RA28 Mustang, sliesh, madmax7, Ae71Rola, 13BT_KE20, and Dave at AJPS for helping me with parts so far :blinks:
Edited by Tally
  • Replies 268
Nice one Tally. Subscribes!
One comment, what engine are you thinking about down the track? I am presuming you will go 4AGE or perhaps 2TG? If so, you might want to think about moving the battery over to the passenger side, if you haven't already, before you get too advanced in your paint work.
Thanks man
Ive removed battery tray and plate, battery will be in boot.... making as much room possible in the engine bay for said engine conversion.
Undecided at the moment on choice of internal combustion engine. so many have potential :P
Edited by Tally
Looks good Tally :blush:
You can tell from how long you have had this thing it is definitely a keeper :P Keep up the hard work and dedication and one day you will be cruising :blinks:
So who is Suzie?? :happy:
haha I knew someone would say something.
Thats just some old lockers my dad and his brothers designed in the early days when they used to play in bands.
Suzie Q surely!?
Very good Tally!
I was wondering what happened to your car. Glad to see you are taking it serious. After all the work, you will be rewarded mate, with a great car to drive. And, the older it gets the cooler it is!
Keen to see it's happening.
Off topic: noticed you want a KE20/25 door. I believe you know the glass is a different shape between the models, but the sheet metal is the same.
what an awsome build well done and look forward to reading more and watching this build as it works towards beening on the road
thanks mate, once it gets painted, thats when the awsomeness will come out LOL
Very good Tally!
Yea mate, well said, wont be too long, not expacting a show car job but it will be a million times better then it was lol....
not fussed about a ke20 door, if i can't find a 25 one ill just unpick the window frame and weld my one in, mainly need a new door as mine has a fair bit of rust which is unusual because the rest of the car only had surface rust...
stay tuned over next couple weeks.
