Oke020
pic from my phone at todays shoot, can't post to many need to wait till feb for the mag to come out. Photographer got shit load of pics hopefully there is a good one in there. Did a skid too :jamie:
Speechless mate...
Awesome awesome work :D
And massive congrads on the feature! can't wait to get my hands on a copy!
  • Replies 419
  • Views 320.9k
  • Hey mate i run some speedflow and some redhorse, the guy i was getting them off has closed shop, not sure if someone else has taken over the distributorship.   As for the ID plates and the boys in b
  • Hey thanks for the comments :), i am fairly certain it could of went 1000 without gas given another run as the tyres were up to temp, also both passes archie got off it at 7800rpm which is 1000rpm sho
  • come accross this vid from power play the other weekend its sick!!!
truly beautifull
Could you possibly fit some sort of stock steel rim on the with some hubcaps? :jamie: Cause thats all it would need to look like a stock ke20.
I would also like to see this......then wait for traction. lol.
who needs traction? live life sideways..... :jamie:
haha, believe me i am currently working out how to get a 7-8" rim on the back that will take a hub cap :jamie:
here is a crappy skid vid from the photo shoot, the 1600cc injectors and all the stop starting i had to do for the shoot fouled the plugs, they cleaned up ok though once i got some boost going. I was supposed to do a static but there was no way the little fronts were going to hold back the 275 et radials lol.
http://au.youtube.com/watch?v=Zr_nxWLTNPk
these were my old wheels when i had the 13bt in it :jamie:
Awesome ... from his vantage point i see no reason why he couldn't have got some great shots .... but your right, those skinny's had no hope in hell of holding on!! they did give it their best though ...
that pic from when it had the 13b is awesome!
so if you had to make a decision.....Rotor or Piston??...this will stir some shit..
don't get me wrong i like rotors, the standard 12a 6 port i had in it originally was lots of fun, once i started trying to push the 13bt though i wasted alot of money in rebuilds, in my experience they are a real maintenance intensive, and rebuild parts alone cost alot of money. Piston engines can be built stronger and are generally more reliable (can't really get much stronger parts for a rotary as yet). In my case instead of using a small capacity highly stressed 4 cylinder as an alternative i decided to go for a 6 cylinder engine. So far its proved reliable and it already makes more power than the 13b ever could and i am not even leaning on it yet |blink| fingers crossed lol
sexual machine, sounds epic!!
cheers, scott
Drove the ol girl to a local dyno comp on sunday, chucked in some fresh 98 octane, still just running on 16 psi wastegate springs, creeps to 21psi at 8500rpm, netted 516rwhp on a 32 degree day, pretty happy at that :jamie: got to remember the car is hardly running a dyno friendly setup, 4.3 gears, 6k convertor, powerglide etc. No evidence of detonation, probably could of been a bit more agressive with the timing and raised the limiter to 9300 for a bit more but its relatively safe running as it is. So far i am loving the 2jz :no2:
Some pics
