Everything posted by Daizy70
Upi Spotted
There was a ke38 at Lonsdale upullit a little bit ago, it was there the other day I think but it's pretty stripped
Ra65 St Coupe
Aren't these called notchbacks? And the ra65s are cool cars not many people know much about them and congrats on finding such a clean one, I look foward to future updates!
- Daizys Bayside Blue Ke70
Ke70 Wags Build
This is a cool build! Good to see a ke70 wagon being built up don't see many people do wagons up, look foward to future updates :)
- The Daily/track 4Age Ae71
Whats A Rusted 86 Shell Worth?
Properly $500 but it's hard to tell with no pictures, how much do you expect it to be worth
Bit of an update was still having electrical problems starting to ending up getting a family friend whos a auto sparky and came to the conclusion to make another relay to the starter because of the voltage drop I was having, Got in contact with the painter and disscussed which parts I will paint and what he will, so stripped the doors and started rubbing them and the bonnet and boot down ready for paint, Primed and painted them the other weekend luckily I got to borrow some heat lamps so that helped to dry the paint in this cold adelaide weather, also drove the car out the garage for a bit of a clean and to see how it sat and how the wheels were. I'm going to get the front guards rolled Now everythings mechanically done, now to rub down and straighten the car panels and off to the painters in about 2 weeks hopefully not to far away, anyway heres some pictures
Peanut Bait
The lights deffiently changed the look abit looks nice, only thing is I think it will look better without that other round badge because its the same shape as the lights it looks like a third light on a angle
- Flares
1979 Ke38 Wagon
I'm pretty sure there's a thread on here about this car if I'm right? This looks pretty clean what's the future plans?
Ke70 Wheels.
You will need to go to a panel beater or get a guard roller and roll your guards or you can run smaller wheels
- Ke70/ae71 Doors
Greenmacs Td Gemi
Seen this out the front of your workshop today looked really straight and shiny
- Trolley Jack Thread
Rusty Relics - Post Old And Abandoned Rollas Here
Where is that ^^^
4K Starter Problem
Just incase anyone wants to know I found out the ignition switch was dodgy so replaced that but still didn't start turned out the brand new starter from repco was dodge aswell so put a spare in and started fine, thanks rian for the help
Havent updated this in a while but cleaned up motor and gearbox and gave the motor some paint, also painted the tailshaft. bolted everything in, put new fuel hoses on and wired everything up, also bought a so called new starter motor. Anyway went to start it a few nights ago and it wouldn't turn over, so changed the starter to a spare one I had still didn't turn over, found out there was only 6v getting to the starter, found out the ignition switch was screwed so flogged one of a ke70 wreck I own and fixed that problem, then put the new starter in and tried to start it again, you could hear the cog pop out but not turn the motor, so out the starter came again and then tested the 2 starters on the ground by bridging the two poles, the old starter seem to have a lot more revolutions compared to the new one, turns out the so called new starter from repco is faulting after changing the starters in and out about 8 times, anyway bolted the spare starter back in and bam the motor started, Was stoked after the amount of messing around we ended up doing, now its just body work and painting left will hopefully be finished soon :) also since the pictures don't show how sparkly the paint is I tried to do a close up but iphone cameras aren't the best, The silver is called satin nickel silver which I painted things with like (brake booster, rocker cover, diff cover, fuel lines and a few other things and the blue is the bayside blue that the car is/will be, so heres some photos:
- Gauging Interest For Upright Manifolds For K Engines
4K Starter Problem
No worrys ill give it a try can i ask where you fund that wiring stuff? thanks for the help
4K Starter Problem
12.4v on battery and yeah have tried jumping the starter it's all fine and the 6v is from the solenoid wire I'm pretty sure, how much volts does the starter need and does the cog have to fully engage to turn it?
4K Starter Problem
Hey everyone just put my motor and gearbox back into my ke70 at first the starter was buggered so bought a new one, now when you try start it you can hear the cog pop out but won't turn, so got the multi meter out and only 6 volts is getting to the starter any help would be a big help thanks
Yellow Ke70, Now White Ke70
Should do a new build thread ^^ :) I'm keen to see how it is now
Ae86 Levin - Shitbox With A Trd Wing
Does that paint have clear coat on it? And I hope your not going to daily it with that paint job the sa cops will rape you haha, apart from that looks like a good build :)
Custom Ke 55 Ground Up Restoration.
Nice build mate I really look foward to more updates :)
