Everything posted by gt500biatch
Ke70 Diff Help !
redwarf, iv crashed with an open diff, and iv drove with this locker for a while, and the locker hasnt caused me to kick out like the open one did on many occasions ...
Ke70 Diff Help !
yeh after i put the motor in it was running smoothly, now there is a fair bit of clunking plus it locks randomly at times :( havnt been driving lately, gna open the diff on sunday (dayoff work) have a look but I'm pretty sure its gone :(
Ke70 Diff Help !
the reason why i don't want an open diff, in my old car i had one, it kicks out randomly when turning and i crashed it once, you counter steer and it can kick the other way randomly... so yeh.
Ke70 Diff Help !
A locking differential, differential lock, diff lock or locker is a variation on the standard automotive differential. A locking differential may provide increased traction compared to a standard, or "open" differential by restricting each of the two wheels on an axle to the same rotational speed without regard to available traction or differences in resistance seen at each wheel. A locking differential is designed to overcome the chief limitation of a standard open differential by essentially "locking" both wheels on an axle together as if on a common shaft. This forces both wheels to turn in unison, regardless of the traction (or lack thereof) available to either wheel individually.
Ke70 Diff Help !
also I'm guessing i just need the centre not drum to drum ? and any T series will do ?
Ke70 Diff Help !
@altezzaclub. would a diff shop be able to do the filling of the teeth ? sounds better than just welding :)
Ke70 Diff Help !
yeh its a 4age 20v pushing 132atw. and no dave i didnt ʞ©$ɟ the diff :( hahaha when i got it of the old owner the diff was already munted :( but now its worse, more jerking,screetching etc.
Ke70 Diff Help !
hey guys, silly question iv got a worked ke70 with a locked diff, the diff is completely ʞ©$ɟed, looking to for a new diff (locked pref.) what should i get (good ratio's etc) nd i can't afford 2 get a LSD so locked will have to do ... cheerz
4Age Ecu Help ?
hey guys, I'm currently running a razorback ecu on a 4age 20v in a ke70, fair bit of work done to her, she is N/A. i was told by mates etc that if i got a proper aftermarket ecu like a haltech or adaptronic etc i would get much more power if this is the case does anyone know what sort of ecu plus where i could get the wiring done ? (local tuner ? etc? ) thanks guys :)
Spotted Qld
i always see a overrated white ke70 in algester ! looks nice sounds carby !
- Spotted Qld
Ke70Daves....Ke70
well its resurecting his car so... thought it was relevent
Ke70Daves....Ke70
oh 4age 20v silvertop :)
Ke70Daves....Ke70
TODA OVER SIZE HIGH COMP FORGED PISTONS C/R 12.5:1 H BEAM FORGED CONRODS ARP HEAD STUDS ARP CRANK STUDS KELFORD 194-C RACING CAMS FULL HEAD RECO PORT N POLISH SUPERTECH 1mm OVER SIZE VALVES SUPERTECH RACING VALVE SPRINGS TOMEI CRANK CAPS TRD 0.8mm MULTI LAYER METAL HEAD GASKET TODA TIMING BELT 1ZE COILPACKS 70mm ITB'S (TRUMPETS) TRD OIL FILTER UNKOWN EXTRACTORS (got em from kaizen garage) 2.25" EXHAUST WITH HIGHFLOW CAT RAZORBACK ecu (was told to get a proper aftermarket one to pull way more power but i ran outa moneys :( )
Ke70Daves....Ke70
Be wooshing past alot of turboz matey :) i shoulda made a thread with my build aye lol
Ke70Daves....Ke70
dude srsly i pretty much bought the SHELL nothing more, the motor was rooted as fk everything was out of shape, so many rust spots and dings interior was munted etc, iv got my motor in etc done a wee bit on the interior and some exterior now to cut and weld the rust out and bog respray etc !
Ke70Daves....Ke70
Some dick really rooted Daves ex :( however i am slowly bringing it back to its glory days, got a beasty 20v in her etc just to do some body work etc now ! threw so much money into her so gta wait for more to come in to do body work
Pics And Vids (*e7* Only)
perfect wank bank <3
Help :) Ke70 4Age Fuelpump
do you remember what it looked like ? coz all the ones i found look different so I'm a wee bit confused lol.
righteo :) thanks again !
its the intank one thats playing up the little black box looking thingo ! its making a shit tone of noise now and its cutting off at times, i replaced the external pump. what intank one should i get ?
- The Cruise Thread
- Ke70 Window Help
4Age Coil Pack Conversion?
google samq, he supplies coilpacks plus coilpack adpater plates, easy and simple to install, even a dummie can do it :) then with your wiring if you don't know what to do get a pro :) lol
Ke70 4Age Problems...
did the motor come with a wiring loom or you using the existing one ?
