Evan G
    3817
    23
Everything posted by Evan G
  1. neg but i should of said "you've seen my gash so why not show me yours?" :lolcry:
  2. lmao nah he need brackets made for the front bars
  3. :POSTPICS!: didnt see the razor blade sticking out my tool box when i was cleaning it. enjoy :rock: edit - the nurse was SMOKING hot and was nice enough to hold it open while i took a pic of my hand :)
  4. 1 tooth is 20 degrees. more than enough to cause it to run like shit. a good trick of mine is when trying to get the oil pump slot lined up with the dissy. get some one to crank the engine while pushing the dissy down. works a TREAT. recheck timing and repeat. make sure you put the bolt that holds the dissy down before revving the engine.
  5. very worked 4k and 5 speed. 10 - 12L per 100km i got it down to 7L/100km. that was on a mega lean set up.
  6. he sold it for 12g. and I'm also rocking a lawn bowl sticker in the same spot :D
  7. solid as a 4k cam!
  8. is she a RUNNER?
  9. munch munch GOR for lunch!
  10. ME GUASTELLA!
  11. refixed man who eats kebab before alcohol, receives no hangover
  12. rofl DERPPPPPP.
  13. as in they used the wrong one? L + R? or that they didnt push the cv joint down?
  14. wait he is correct on this one dam you baker!
  15. the switch shouldnt have power going to it. it earths out when open and the ligh comes on. remove the switch and touch it the body. light should work. getting 12v to the globe?
  16. the wiring goes thru the drivers A pillar. could be the bullet connects have come loose. also check your door light switches
  17. lol says this on fb great ocean road 2012! Thursday, January 26 at 6:00pm also says 36th in the description of this topic :)
  18. DERRRPPPP thursday (26) and friday (27th) at the trailer park. rest at national park
  19. you need that one way valve connected to a good vac source and the other tube to be filtered
  20. baker is called toyota black or is it a black sealant?
  21. we still got a hand full of spots of spots left ladies and jellyfish. this is next thurday! would anyone be keen to do a pre run to the first meet point on the weekend?? i got nfi where it is :D
  22. threebond is the BOMB! after 5 sump gaskets on 2 k motors i also found removing all the studs and using bolts and washers also help just don't over tighten them!
  23. pics link ban?
  24. 12a with noisy lifters :P
  25. thanks chief! i was trying to copy masons design i love mechanic secs. the fuel gauge drops as soon as you hear induction but :P
