Evan G
    3817
    23
Everything posted by Evan G
  1. should i make this my new sig?
  2. if you get a more postive offset wheel and longer control arm? bent struts ftw
  3. $875?? LOL! i would do a cashy for $100. but dead set get another motor. $875 isnt worth it.
  4. hey ho lets go!
  5. I'm bring a weber for him on sunday, he was trying his luck to see if anyone had a spare. :lol: is stu still coming to this? his answer will depend if i bring the rolla or seeda
  6. :lol: i replace my dissy oring and re installed my dissy. set my timing by ear. checked it when i got home. was 1 tooth out and idling at 40/60 degrees advanced LOL! didnt like to rev at all. all fixed now. brakes need a real good bleed as they feel inoperative :/
  7. i measured 20 tho machinist removed 40 and was 10:1
  8. they all make baby jesus cry!
  9. rubbish! :P
  10. hohoho 28/36 DCD. mechanical sec :D so currently have 3 32/36dgav, 1 28/36 and a 28/36 dcd LOL anyone need a weber? wheel bearings are done for GOR! just need some decent 195/60R14 tyres! these 175/70 can't handle corners or the might 4k power! nomnomnomnom
  11. thats leighroy rolla man can
  12. man that spring diameter looks MASSIVE. its prob 13/15kg spring easy!
  13. take the radiator out and get it professionally flushed. cheaper than a replacement. then run some radiator cleaner thru it (or do this before getting it flushed)
  14. take the radiator out and get it professionally flushed. cheaper than a replacement. then run some radiator cleaner thru it (or do this before getting it flushed)
  15. http://www.rollaclub.com/board/topic/42018-how-to-wear-in-my-4k/page__hl__%2Bbedding+%2Bin__st__30 there you go
  16. Nonsense! Me? Nooooooo
  17. I'm going to call you passion fingers from now on Because everything you touch you ʞ©$ɟ!
  18. smash a 6 point socket on it!
  19. theres no holes in the intake. just the exhaust. just leave it hanging.
  20. do you mean the hot box? the 3 bolt triangle thing in the middle of the manifolds?? if you get a weber you need a adapter plate witch makes the weber bolt straight to the stock mani btw want a 32/36? i got a couple for sale :rolls:
  21. the rose joints are CHEAP! buy from jegs or ebay. when i was going to start fabricating strut braces, i was on the hunt for rose joints. my local hardware/hose joint wanted $47 per joint! i found some online for $11.... fml
  22. what little redspirit said!^^ a member on here had a ksev with choppies and sierra shocks. it was dangerous! no droop. very twitchy and just wants to oversteer. (this was at 100kph :| ) rear end was rock solid. save your self $140 and just install metal tubing as shocks! do NOT recommend them. go commodore wagon rear shocks
  23. so why rip the engine if it runs soooooo good? Doesn't make sense to me
  24. what philbey said! everyone says big cams a pig. what a croc! my cam kicks in at 3500rpm and after every gearchange I'm in my cam range small flat spot but it can be tuned out
  25. yea do that first but with a test wire. don't run it all professional and realise it doesnt work.
