Evan G
    3817
    23
Everything posted by Evan G
  1. orite i understand about turbso etc how they work etc etc but the question people at work can't answer is if i got 8.5:1 compression. (160 psi lets say) with 8psi of boost does that mean the compression is gonna be around the 168 (give or take)? hence having a LOW compression 7.5:1 (150psi lets say again) and boost it to 20 pounds and still be a safe compression?
  2. sedan = coil springs van = leaf springs
  3. one thing ive noticed is 5k electronic dissy in a 4k doesnt feel right? even with the same timing etc etc 5k electronic dissy in a 5k, everything feels like it was made for eachother 4k advance weights must be different to the 5k ones?
  4. :| all this cut spring talk will awaken the mods. mr dwaft especially
  5. is this a carolla or corolla? (hint to fix your topic name :D)
  6. i wonder if i "arrested" him till the cops came would i get f@$ked over cause i had no proof? yea maybe the cctv at the plaza would of saw him. but he could just deny it all?
  7. walking back to the car from the plaza. jump inside the car. look up and there a guy with a big bag looking under the tarp of a ute. looked a little sus. he walked off pulled his keys out and pretended to central lock the ute. no lights/horn when off. thats when i knew something was going on. drove off and pulled into a car spot in-front of the plaza and bolted in looking for a security guard. found one told him the situation and he followed me out to find him. soon as we walked out the doors there he was looking under another tarp of a builders ute looking for tools etc etc. he called for back up as i was walking to the car. HOPE THAT SCUM BAG GOT f@$kING CAUGHT! pinch some tools and go to cashies for some money for drugs. just a head ups don't leave tools and other valuables unsecured in the back of the ute. dog c**ts!
  8. :hmm: got pics and videos to confirm this? ^^^
  9. you fill it with ep80w, fill it till the oil covers the top of the gears nfi on a drian plug
  10. "bog stock" dead standard
  11. yea a bog stock 3k with a HD clutch would chirp 2nd :glare:
  12. HELL YES!
  13. parts pbr hd clutch $100 extreme hd $180 exedy hd $280 fitting depends on your mechanic
  14. basically anything fit! (use the front mount witch bolts straight up into the hosuing not on the side. aslong as its nice and thick and got a hole in the middle sould be fine. line it up with the x member/drill the holes and she'll be sweet i used a engine mount out of a booze bus generator i found at work :lolcry:
  15. depends how mechanically retarded you are? your looking around the 1800 mark if a engine rebuilder has to do all the work, all you do is drop it off and tell him what you want and bend over.
  16. the shifter isnt as far back to be a 70 box? ^^^ thats a ke55 5 speed box above
  17. theres a fella in tas with a 5k with twin side drafts, cam. pulled 66rwkw
  18. i had the same problem on my 55 with the idler arm touching the exhaust, get the grinder in there and cut a little tab off
  19. my worked 4k keeps up with a bog stock 5k (he had a passanger aswell) 5k = no clutch kicking in the wet
  20. +1 if i cbf with stands. just a couple stockies under the seals just incase
  21. had a blown hg $100 5k for a while till the 4k was getting re checked. this thing was DEAD silent! sounds like too much effort since the motor isnt apart
  22. vac or mechanical secs? bogs down & loses all power = lean bogs down and slowy picks up then its fine = rich i also had a problem of it would lose all power at 3000rpm + turned out the coil was shorting out to the postive terminal edit http://www.vw-resource.com/jets.html have a GOOD read through that, explains how everything works and how to work out the basic tuning/diagnostic
  23. ROFL!!!!^^^ you forgot the HUGE for sale sign on the rear window next to the southern cross
  24. lmao yes please, will stock up on red bull. we'll see what happens :blinks:
