Evan G
    3817
    23
Everything posted by Evan G
  1. yea man have to bleed the brakes. so when the brakes kick in its 30-40mm down?
  2. are those spool rods? better start stocking up on K gearbox's with that clutch :hmm:
  3. i would say only a ke70 4k would work cause its got a single round outlet not a twin like 30/55's then depends on how much egr and emisson crap you wanna keep
  4. 28/36 is a great mixture of fuel economy and performance once at full throttle
  5. nah bro panda and welded = street credit or showing your too poor for a Zenki LSD?
  6. that better be a track car or your a tool
  7. i would just go for some webers or twin su's. aisin carbys are good for a standard engine anything tickled go a weber
  8. keiran ask trev if he machine's cylinder heads. kthxbai
  9. they weigh like 15kgs standard. there was a fella from finland i belive that got the weight down to 4.7kg with fiberglass replica
  10. did you change the input and output shaft bearings? if you have oready put it back together theres no point explaining it
  11. the one thats one piece. its got a circlip holding it in. remove it and the centre of the shaft pulls out
  12. i went and spoke to my local engine rebuilder who does alot of perforance work so he knows his shit. i asked him about pricing on crack test the block etc etc and he laughed and said "i only crack test things when something goes on the engine and puts stress on everything else aka spun bearing/blown hg etc etc. if its just a general rebuild i don't do it" so i wasted $330 on my engine build that could of gone to something more worth while
  13. all done? need to remove the cluster shaft, then theres a HUGE circlip behind the input shaft. then it drops out ask me for more info if yah need, ive rebuilt a k50 before
  14. there was a overrated 87k 1981 ke55, this thing was dead set overrated. interior was spot less. drive line no leaks. no rust in the body i drolled :huh:
  15. carbon fiber vinly wrap the bonnet ftw! :y:
  16. OLDSCHOOL!
  17. :dance:
  18. sellers making new topics for the same items! :bash:
  19. theres brank spankers on ebay in malyasia
  20. did they check bearing preload and if the theeth of the pinion meet centre of the crown?
  21. hey mate, while you have the head off. poor kero into intake and exhaust ports of the cylinder witch had nut inside of it, then check the valve and see if theres fluid leaking out leaking = bent valve or damaged seat/guide no leaking = all good mate edit - if the nut was that big howd it get in there? wouldnt have gone down the valves?
  22. :lolcry: :lolcry: :lolcry: :lolcry: :lolcry:
  23. thats it!
