June 21, 200719 yr comment_183173 check out these pics. they go that way too ----------> Edited June 21, 200719 yr by JC807 Report
June 21, 200719 yr comment_183174 At least the bulk of the metal went downwards I guess. I have seen a movie of a rotary powered wagon that had a flywheel explode. Bits of metal went upwards and fell amongst the spectators at the drag strip. Report
June 21, 200719 yr comment_183183 Note to self... re-torque flywheel bolts next time I have the clutch out Report
June 21, 200719 yr comment_183186 .... and you thought he was having a sucky day. :jamie: Boeing 767 doing ground runs in the States. This is where it started...... This is what it went through...... This is where it ended...... ...... whoops! Brown trousers! Edited June 21, 200719 yr by Redwarf Report
June 22, 200719 yr comment_183212 At least the bulk of the metal went downwards I guess. I have seen a movie of a rotary powered wagon that had a flywheel explode. Bits of metal went upwards and fell amongst the spectators at the drag strip. listen to the commentator ask if anybody in the crown has been hit!! :jamie: Report
June 22, 200719 yr comment_183236 Oh the memories , i did something similar in my RX2 many years ago at the old eastern creek except it was my clutch pressure plate that exploded , shattered the bell housing snapped half the rear end plate of engine off , cut clean through the exctractors and very luckily only just cut into a fuel line but didn't go through the hose , was a long time till back on the road had to replace everything behind radiator back to tailshaft was quite expensive Report
June 22, 200719 yr comment_183289 Red I know those gas turbine pics well..lol MMM bit of a hot start you could say..lol I have seen a jet powered go kart similar to the one I made lift off the ground doing 100km/h when its single 100mm diameter turbine let go at 80,000RPM so imagine a Boeing 767 engine letting go...... Cameron Report
