awvg Posted July 27, 2007 Report Posted July 27, 2007 hay guys ... just doing a little research into lowering my rolla.. the rear shocks are gone so was going to upgrade them when replacing but was wondering if i am going to lower the rear will i need shorter shocks... also what shocks do you guys recomend ... is it a hard process to do myself swapping shocks and lowering the car all round... oh and also what set up at the front do you guys also recomend keeping in mind i want to do it properly not dodgy like cutting the springs etc... Quote
leigh Posted July 27, 2007 Report Posted July 27, 2007 hay guys ... just doing a little research into lowering my rolla.. the rear shocks are gone so was going to upgrade them when replacing but was wondering if i am going to lower the rear will i need shorter shocks... also what shocks do you guys recomend ... is it a hard process to do myself swapping shocks and lowering the car all round... oh and also what set up at the front do you guys also recomend keeping in mind i want to do it properly not dodgy like cutting the springs etc... http://www.rollaclub.com/board/index.php?s...=lowering+a+car :y: Quote
Jordan Posted July 27, 2007 Report Posted July 27, 2007 if you're in adelaide, we can have it done in 60 minutes :y: jsut bring the beer and the beats Cheers Jordan Quote
awvg Posted July 29, 2007 Author Report Posted July 29, 2007 na nsw unfortunately .. thanks alot for the offer though Quote
anastasios Posted July 29, 2007 Report Posted July 29, 2007 yea seriously just get an angle grinder and the fronts done, with the rear use blocks, u might get lucky with ride quality Quote
ScottKE1X Posted July 29, 2007 Report Posted July 29, 2007 I gave king springs and reset rear leafs you can buy if you wanna do it all legit and legal. In SA though so may cost a few $ in post... pm me if interetsed. Quote
flat out Posted July 29, 2007 Report Posted July 29, 2007 don't use lowering blocks, they will make your car tramp realy bad, flip some leafs and add a couple, harder suspension and no tramp what so ever. Quote
Jordan Posted July 30, 2007 Report Posted July 30, 2007 ^^ good advice, that's what we do. Jordan Quote
MRMOPARMAN Posted July 30, 2007 Report Posted July 30, 2007 don't use an angle grinder to lower coil springs either, the heat generated softens the metal, and they just keep breaking bits off. seen plenty of dunnydores done that way, and ya look in the lower control arms where the springs sit and theres 5-6 lengths of coil that have broken off :y: you can buy new springs for like $100 or so, just do it properly and ya wont regret it. you should get shortened shocks when lowering a car, as if you jack up the car, the spring will unload before the shock runs out of travel, and they can cock sideways, or fall out. also if you lower alot without changing shocks, they can bottom out when going over bumps and stuff your shocks Quote
Jordan Posted July 31, 2007 Report Posted July 31, 2007 I thin you'll find heating steat makes it harder, but more brittle. However if steels are left to air cool, they tend to retain much of their initial properties. unless they are air hardening steels like Reynolds 631 or 853. If quenched (cooled quickley in water, snow or oil) then they become very brittle. but very very hard. you can then temper the steel by reheating it to a lesser tempreature eg: 300dec C and allowing it to air cool. this tuffens up the steel. Cheers jordan Quote
anastasios Posted July 31, 2007 Report Posted July 31, 2007 i don't think his going to heat them himself Quote
Jordan Posted July 31, 2007 Report Posted July 31, 2007 I agree, but MRMOPARMAN in post #10 suggested that he'd ruin the spring's temper but getting stuckinto them with a grinder. Cheers Jordan Quote
coln72 Posted July 31, 2007 Report Posted July 31, 2007 Agree with Jordan on that one. Least I learnt something in my metallurgy course. PS. ran cut springs for 15 years without any problems, part from being illegal I do not have a problem with cut springs. Also if they fall out when the car is jacked up, zip ties are your friend :n: Quote
Jordan Posted July 31, 2007 Report Posted July 31, 2007 Tips for the novice spring cutter: tip no.1: don't get over zelous, cut 1 coil first, see how it sits, the cut more. you can't put coils back in. Tip no.2 Use a peice of stiring to measure how much metal has been removed from the first side. With the string trace the other sides coil so they are both even. Cheers Jordan Quote
