November 25, 201213 yr comment_637679 When your fuel lift pump sounds like a machine gun. grrrrrrrr I double checked there was nothing in the fuel lines, cleaned them all out and everything, and this is a new Facet fuel pump. Thinking it might be a chinese copy though... It quitens up a fair bit once it has a good flow of fuel running through, but once it runs back into the tank again - crack-crack-crack-crack-crack don't ʞ©$ɟ with me, ke70. Now that your tank has petrol in it and the fuel pumps half work its easy to set fire to you. Report
November 25, 201213 yr comment_637693 When your fuel lift pump sounds like a machine gun. grrrrrrrr I double checked there was nothing in the fuel lines, cleaned them all out and everything, and this is a new Facet fuel pump. Thinking it might be a chinese copy though... It quitens up a fair bit once it has a good flow of fuel running through, but once it runs back into the tank again - crack-crack-crack-crack-crack don't ʞ©$ɟ with me, ke70. Now that your tank has petrol in it and the fuel pumps half work its easy to set fire to you. I though all facet pumps are loud? I don't like them. I just went intank for the lifter on my 70. Edited November 25, 201213 yr by It's_AUDM_Yo Report
November 25, 201213 yr comment_637706 Yep standard Facet noise. Deal with it. Rubber mounting will help deaden the noise a bit. Report
November 25, 201213 yr comment_637718 Working from 8am Saturday to 2:00 ish Sunday arvo and being awake longer. Makes doing simple stuff like typing fun................................ Report
November 27, 201213 yr comment_637931 Oh really haha? Yeah i can deal with it, as long as it works. I just thought it was cooked ha Cheers for that Report
November 27, 201213 yr comment_637932 Pinched nerve in my neck.. Forget how much your neck is involved in EVERYTHING you do when it happens. Report
November 28, 201213 yr comment_638052 No comparison but it's like that when you break a finger or a toe. You never realise how much you actually use it. Did my thumb in late last year and it's still not right. Report
November 28, 201213 yr comment_638059 How long it takes frozen pies and sausage rolls to cook in the oven.... GIVE ME FOOD DAMMIT!!! Also, being forced in to taking annual leave because you have to much, and not getting a chance to make plans.... So boring 8/! Report
November 28, 201213 yr comment_638060 How long it takes frozen pies and sausage rolls to cook in the oven.... GIVE ME FOOD DAMMIT!!! Also, being forced in to taking annual leave because you have to much, and not getting a chance to make plans.... So boring 8/! microwave them first, then oven to crisp them up ;) Report
November 29, 201213 yr comment_638174 The missus flew into NZ, and forgot she had an Avocado in her handbag from her lunch the day before. $400 fine. Report
November 30, 201213 yr comment_638246 oh not cool reedo. alot of you may not undestand what I'm talking about....but what is grinding my gears at the moment is bloody farmers bringing in grater split rims that were old when the titanic sank, and expect us to be able to find and fit tyres to them with buckled lock rings and the paint holding the rust together....shits not going to end well Report
November 30, 201213 yr comment_638253 oh not cool reedo. alot of you may not undestand what I'm talking about....but what is grinding my gears at the moment is bloody farmers bringing in grater split rims that were old when the titanic sank, and expect us to be able to find and fit tyres to them with buckled lock rings and the paint holding the rust together....shits not going to end well Sounds kinda explosive. The last time i saw a split rim was on a land cruiser back in the middle ages. I thought the split rims were banned now a days ? But then again, farm vehicle and the farmer's are most likely from the bronze age or something. Report
November 30, 201213 yr comment_638290 no split rims still come out on some 4x4's, they were made to be easier to change on the go. the ones that have been banned/not supposed to have are called suicide rims. they basically live up to their name too, where instead of having a normal lock ring, the whole top half of the rim is the lock ring....we arent allowed to do them anymore, and with good reason. Edited November 30, 201213 yr by madKE35coupe Report
