Gavclassic Posted June 18, 2008 Report Share Posted June 18, 2008 The 4:1 ratio in my KE17 is way to short. Looking for a bolt in replacement thats about a 3:7. Otherwise what ratios can yoy get for a KE30/55 rear. Any advise would :) be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted June 18, 2008 Report Share Posted June 18, 2008 Pretty sure 55 diffs are 3.9 for manuals and the autos are 4.something Quote Link to comment Share on other sites More sharing options...
corolla_nut Posted June 18, 2008 Report Share Posted June 18, 2008 There were 3. In a borgwarner there was 3.89:1 a 4.1:1 and a 4.3:1. Never seen a 3.89:1 though. I don't know what you can or can't get in a jap diff, have a funny feeling that the autos have the taller ratio. Quote Link to comment Share on other sites More sharing options...
corolla_nut Posted June 18, 2008 Report Share Posted June 18, 2008 Also, the reason why you have such a short ratio is that you have a very small rubber band for an engine and it doesn't have the torque to pull you along at higher speeds that you would get out of a nice tall differential. Ideally you'd need a bigger engine to run a taller diff. I'm under the impression a ke17 was designed to be a snappy little car and you lose that snappiness with a smaller diff. I'd be happy with the 4:1. Quote Link to comment Share on other sites More sharing options...
KE70-from-mt-panorama Posted June 18, 2008 Report Share Posted June 18, 2008 Gavclassic has a 7k in his ke17, so i don't think power at high speeds will be a drama. (from memory he is going to be using it for circuit work) correct me if I'm wrong though cheers Quote Link to comment Share on other sites More sharing options...
13BT_KE20 Posted June 18, 2008 Report Share Posted June 18, 2008 you might find a 3.7 to be a bit long......... I ran a 3.6 in my old S2 RX7 for a while (before changing back to 3.9), but it was waaaaaaaaaaayyyyyy to long. I'm talking 80 in first, 120 in second, 3rd was............... i think a 3.9 would be better if your looking for a taller ratio, altho i don't know why you really want to change it. I loved the 4.1 in my RX7. IMO 4.1 is perfect for an NA car Quote Link to comment Share on other sites More sharing options...
Felix Posted June 18, 2008 Report Share Posted June 18, 2008 (edited) He needs a taller diff ratio because he is making peak power at 6200rpm. Going from a 4.1:1 to a 3.7:1 would drop the cruise revs at 100kays by about 300rpm, plus boost the top end speed by around 20km/h at peak power rpm. Gav if you are running the Borg Warner diff, Datsun 120Y's share the same diff style (BW68) but have 3.9:1 gears. I'd also look at 2L sigmas, as apparently some had the smaller Borg Warner diff in them. Also maybe look at datsun 200B's... My ACL gasket catalogue tells me that some share the same diff gasket as ke55's. Edited June 18, 2008 by Felix Quote Link to comment Share on other sites More sharing options...
Gavclassic Posted June 18, 2008 Author Report Share Posted June 18, 2008 Thanks guys! At the moment my KE17 runs the original Jap dif, 4:1 is standard, 4:3 is what comes out of the KE18 wagons. My other option is to cut down and RX 7 S2 or S3 disc rear end. If i'm going to go down the Mazda option i need to make sure i can get an LSD for it with at least a 3:9 ratio. :lolcry: I'll also be using the front brakes of the Mazda just to keep it all balanced. Quote Link to comment Share on other sites More sharing options...
Jono Posted June 18, 2008 Report Share Posted June 18, 2008 the ke55 bw auto is 4.33:1. which sucks for the freeway. Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted June 18, 2008 Report Share Posted June 18, 2008 I can help now!! :lolcry: S1 (s1 has drum rear) & S2 rx7's are 4x110 as you know, but s3's are actually 4x114.3! ;) S3 factory race lsd's aren't too hard to find, but you don't want that stud pattern. Best bet for a s2 lsd is a guru centre (looking at about $1000 with no gears. Then, here's the bit you'll like - the S2 centre being mazdas "medium sized diff" came in many many cars throughout the years, hence giving you HEAPS of ratios to choose from..... 1500 wagon – 4.675:1 ratio 1500 sedan – 4.11:1 R100 – 3.7:1 or 3.63:1 Capella – 3.9:1 RX-2 auto and late 3.9:1 RX-2 early manual 3.7:1 RX-3 – 3.7:1 1600cc 808 – 3.7:1 929 – 3.9:1 (later cars had 3.909:1) 12A RX-4 – 3.9:1 121 – 4.11:1 626 – 3.9:1 929L – 3.7:1 E1300 – 4.875:1 E1400 –4.44:1 E1600 – 4.1 E1800 / 2000 – 3.9 Most Diesel vans were around 3.9:1 1st Generation RX-7 – 3.9:1 For more info on Mazda diffs, there's not much that isn't covered in this thread...... http://ausrotary.com/viewtopic.php?f=16&t=2695 Quote Link to comment Share on other sites More sharing options...
13BT_KE20 Posted June 19, 2008 Report Share Posted June 19, 2008 I can help now!! :lolcry: S1 (s1 has drum rear) & S2 rx7's are 4x110 as you know, but s3's are actually 4x114.3! ;) S3 factory race lsd's aren't too hard to find, but you don't want that stud pattern. Best bet for a s2 lsd is a guru centre (looking at about $1000 with no gears. Then, here's the bit you'll like - the S2 centre being mazdas "medium sized diff" came in many many cars throughout the years, hence giving you HEAPS of ratios to choose from..... 1500 wagon – 4.675:1 ratio 1500 sedan – 4.11:1 R100 – 3.7:1 or 3.63:1 Capella – 3.9:1 RX-2 auto and late 3.9:1 RX-2 early manual 3.7:1 RX-3 – 3.7:1 1600cc 808 – 3.7:1 929 – 3.9:1 (later cars had 3.909:1) 12A RX-4 – 3.9:1 121 – 4.11:1 626 – 3.9:1 929L – 3.7:1 E1300 – 4.875:1 E1400 –4.44:1 E1600 – 4.1 E1800 / 2000 – 3.9 Most Diesel vans were around 3.9:1 1st Generation RX-7 – 3.9:1 For more info on Mazda diffs, there's not much that isn't covered in this thread...... http://ausrotary.com/viewtopic.php?f=16&t=2695 sumed it up very nicely there Taz Just thought id add that S1/2 are 24 spline axles and S3 are 26 spline axles. Therefore S3 diff/axles are a fair bit stronger. If you plan on running wide rubber/slick you may find the S2 to be a bit weak. you may find your twisting/snapping axles. Bit your not running a great deal of power so a S1/2 way hold up. Quote Link to comment Share on other sites More sharing options...
Felix Posted June 19, 2008 Report Share Posted June 19, 2008 I'm not sure about the ke17's, but the ke15 sprinters had a 4.22:1 diff standard. The ke16 wagon had a 4.44:1 diff standard. Pretty sure the ke70's with jap diffs had 3.9:1 ratios. They are not very common though. Quote Link to comment Share on other sites More sharing options...
Gavclassic Posted June 19, 2008 Author Report Share Posted June 19, 2008 I can help now!! :lolcry: S1 (s1 has drum rear) & S2 rx7's are 4x110 as you know, but s3's are actually 4x114.3! ;) S3 factory race lsd's aren't too hard to find, but you don't want that stud pattern. Best bet for a s2 lsd is a guru centre (looking at about $1000 with no gears. Then, here's the bit you'll like - the S2 centre being mazdas "medium sized diff" came in many many cars throughout the years, hence giving you HEAPS of ratios to choose from..... 1500 wagon – 4.675:1 ratio 1500 sedan – 4.11:1 R100 – 3.7:1 or 3.63:1 Capella – 3.9:1 RX-2 auto and late 3.9:1 RX-2 early manual 3.7:1 RX-3 – 3.7:1 1600cc 808 – 3.7:1 929 – 3.9:1 (later cars had 3.909:1) 12A RX-4 – 3.9:1 121 – 4.11:1 626 – 3.9:1 929L – 3.7:1 E1300 – 4.875:1 E1400 –4.44:1 E1600 – 4.1 E1800 / 2000 – 3.9 Most Diesel vans were around 3.9:1 1st Generation RX-7 – 3.9:1 For more info on Mazda diffs, there's not much that isn't covered in this thread...... http://ausrotary.com/viewtopic.php?f=16&t=2695 Thanks heaps! I've actually got a S3 RX 7 thats basically a rolling shell that i bought for the disc rear end. If i was going to use it i also intended to use the front brakes as well, then front and rear would have the 4 x 114.3 stud pattern which is a bit easier to find 14" alloys in. My S3 RX 7 is an auto, but i don't know the ratio yet. If i could find a S2 disc rear and front brakes and struts for reasonably money i'd consider using them instead. Quote Link to comment Share on other sites More sharing options...
lappy Posted June 19, 2008 Report Share Posted June 19, 2008 3.7 that fits in to a 30/55 housing is a 3.7 rear diff from an AL25 Tercel. Half of the speedway guys I race against run them so the source is very reliable. Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted June 19, 2008 Report Share Posted June 19, 2008 Hi, I will back up Felix statment about KE1X ratios. I got more sprinter manuals in mail today and the KE15,17 had 4.22:1 ratio diff. The later KE2X car had 4.1:1 ratio as it advertises the fact in my manuals that the KE2X has higher top speed lower revs yada yada. Also KE1X wagons have 4.44:1 also as Felix said. So Gav if your KE17 is a 4.1:1 is it the original diff still? Cameron Quote Link to comment Share on other sites More sharing options...
