K Engine Extractor Price
  • Replies 69
  • Views 62.8k
this mean ke35 will only be fitted with ke30 extractor. Daamn, luckly i don't scold and buy that ke20 extractor yet.thank slapper....
Slapper, welcome to Rollaclub and thanks for that info.
Do you mind if I add it to the FAQ?
Cheers
no problemo - whack it in the FAQ
Incidentally, the remedy for 3X extractors vs the 2X gearbox x-member problem is to weld a U-shaped relief into the gearbox crossmember so the exhaust can go wherever it wants. I suspect I dropped some photos in the oldcorollas piccies area if you're keen.
However (there's always a however!) ... you also need to worry about the steering idler arm ... because the 3X engine bay is slightly wider, my 3X extractors swung further away from the engine than was a good idea for the 25 - resulting in a nice little dent where the steering idler thumps into them on hard left turns (made worse by the engine twist when you rev).
All up, I had the exhaust shop heat, bash, bend etc to the point where I would've been better off buying brand new 2X specific extractors than the $50 wrecker specials plucked from a KE30.
Slapper
I suspect the 2X extractors *would* fit a 3X ... if you were replacing the rest of the exhaust as well.
The 2X exhaust hugs the transmission inbetween the floor, the gearbox and the x-member. It certainly looks like this would still work with the 3X as well as the 2X (apart from the 3X good idea of routing the exhaust heat *away* from the gearbox rather than right next to it).
You'd need to replace the rest of your exhaust as well as it would be in a different spot under the floor.
The 2X extractors hug the engine tighter as the engine bay is smaller *and* they need to hug the gearbox.
All up, it would certainly be a safer bet that 2X extractors would fit a 3X car, but the safest bet wuopld be that 2X extractors would fit a 3X car :D
Slapper
i'm going to cut up my spare ke20 gb crossmember and do welding mods for the racecar, with side exit exhaust, i need all the muffling space i can get :D
and i can guarantee you all that ke30 extractors don't fit a ke70
Or you can get lucky like me an score a decent ke20 shell with a 5k, extracters, and a 2inch exhause for 400 bucks off a guy who really needed rego money :) :D
just make sure you have mandrel bent primaries. press bent ones look smaller than factory runners, it be more fun tying em to the towbar
picked up a brilliant set of genie extractors 4 into 2 into 1 for 50 bucks used only once from the 4,6 and 8 shop in adelaide still have the blue coating on them if you look hard enough you can still find a good deal
