Quick Question About Tyre Pressures
So the placard in my corolla says that my tyres should be at 24 psi but when they're there they seem too low. I have the original stock wheels on. What is the best pressure to have them at?
What model is it?
If anything id recommend 34psi for the usual 175/70 13
Yeah if they are 13's or 14's id still stick with 34psi for day to day driving, it gives good wear and good performance.
Tyre pressures move with new technology and time :jamie:
Edited by Karllos
I really doubt a 91 seca would say 24 psi? thats kinda weird
please don't put 34psi in them, you will understeer/oversteer in the wet and dry like theres tomorrow
B/S.
can you care to explain how? I'm curious
Although you don't recommend what pressure to run?
Karl.
Edited by Karllos
Karl.
well this is from my personal experience, i ran 34 front 38 rear cause i though 26 was a bit low,
used to understeer quiet badly in the wet. in the dry it used to under steer when "spirited driving"
I'm running 30 rear/ 26 front and noticed ALOT less understeer
B/S.
:jamie:
Look at the recommended pressures printed on the tyres sidewalls and experiment from there.
Personally I've found with RWD cars I like running the fronts about 4 psi higher than the rears. A FWD will probably be a bit different though.
On my ke15 (185/60x13 A539s) I run 44psi front / 40psi rear. SFA sidewall flex, plus even tyre wear with regular tyre rotations. Neutral steer with awesome traction both wet and dry.
Tyre quality plus suspension setup makes a MASSIVE difference to how a car handles.
Edited by Felix
I'm slack but i try to keep about 32 all round with 205 wide 13's
and has given me even wear and not much trouble
:jamie:
Yeah experimentation is really the best way to go about it, at my old work we ran 3/4 of the cars with similar sizes at 34psi. Then again it all depends on how you drive and what you want out of it.
Personally i run 42psi in my fronts and 40 in my rears, although i do have 205/40 17's
Karl.
i put my rear ones at about 5-6psi more FOR DA DRIIFFFTTSSS*
*author of this quote may or may not drive a ke70 with a 4k, henceforth making drift nigh on impossible, consequently making statement untruthful
have a nice day
