April 15, 201016 yr comment_429866 i was just sitting around going though a fastfours mag and was wonder has any one everytryed twin turbos on a 4k or 4AGE engine? see all the bigger motors twin turbo but never little ones. would twin garrett GT1241 work? please no it would but its would be easier to just go single. i wont to know about twin turbos Report
April 15, 201016 yr comment_429868 There was a kit years ago to twin charge (super and turbo) a 4age. HKS if I remember. Report
April 15, 201016 yr comment_429874 Most twin turbos cars run sequential turbos - meaning one will spool quicker than the other, and hence the other will give better top end. Its was basically for a bit of a compromise to try and get good power and torque throughout the rev range. Most twin turbz cars just get converted to singles for better top end with a loss in low-mid response being the expected compromise. I would like to do a twin turbo 7k one day with twin CT12's off a 1ggtte, but it would only really be for wank factor. Again you'd probably be better off with one well suited turbo like the TD04-L I used to have. Report
April 15, 201016 yr comment_429876 I believe the main reason that smaller engines don't usually have twin turbos is that they don't have the displacement of larger engines - meaning there is less air to be pressurised, so you don't need as many air pumps. One turbo is generally smoother, cheaper and simpler for the manufacturers, and if it's a small engine in the first place, then it's perfectly suited. :wink: Report
April 15, 201016 yr Author comment_429885 yea all good point just be some thing really diffrent. might bejust a fun thing to do for a daily or so thing yes? Report
April 15, 201016 yr comment_429890 yea all good point just be some thing really diffrent. might bejust a fun thing to do for a daily or so thing yes? Its been done recently and in Brisbane. It was done by sam from razorback (formerly). The car was for sale a while back. It may have been sc and turbo but I can't remember. His username was "fox" or something. You could probably find it by searching the members and then his topics. From all accounts it went awesome. Report
April 15, 201016 yr Author comment_429896 i found him his user was "foxtail" all i could find on it was the car forsale but I'm pretty sure its not twin turbo any more? Report
April 15, 201016 yr comment_429902 It was twincharged, not twin turbo, Have looked into it and would only be beneficial with 2 IHI RHB31, Doubt I will ever do it. Report
April 15, 201016 yr comment_430022 Most twin turbos cars run sequential turbos - meaning one will spool quicker than the other, and hence the other will give better top end. Its was basically for a bit of a compromise to try and get good power and torque throughout the rev range. That stands true for inline engines, but V6/V8s etc tend to run two small parallel turbos, one feeding off each exhaust bank to make piping easier. Report
April 15, 201016 yr comment_430036 Hmm probably should have mentioned that. Subaru should have also just made all there turbo's cars twin turbo. :jamie: Report
April 16, 201016 yr comment_430050 going against hiro's logic though, the B4's were sequential twins. It looks like the GT2 Porsche is twin parallel, but they've got all sorts of fancy variable vane stuff on them anyway. Wonder what the older models had... Report
April 16, 201016 yr comment_430054 twin t28 i reckon or a small turbo for low end and a big turbo for high end Report
April 16, 201016 yr Author comment_430062 So if you wonted good power down low and up top you would have to run a smaller turbo and when that is spolled the bigger one kicks in and takes over? Is it as simple as just making a twin turbo manifold and outing one small one bigger turbo on or do you have to set it up in a diffrent way? Report
