September 1, 201214 yr comment_624402 Don't want to seem like a dick or anything, But why is an $8000 gearbox needed in a Ke70 that weighs bugger all? Surely the stock LS gearbox would be more the strong enough, Unless you're planning to have no mechanical sympathy in terms of clutch dumps etc? Report
September 1, 201214 yr Author comment_624425 because you can't flat change a stock ls gearbox... its a jerico dogbox with shiftcut and you hold the pedal flat and change gear as fast as you can move your hand.. worth 2 sec a lap Report
September 1, 201214 yr comment_624445 Don't want to seem like a dick or anything, But why is an $8000 gearbox needed in a Ke70 that weighs bugger all? Surely the stock LS gearbox would be more the strong enough, Unless you're planning to have no mechanical sympathy in terms of clutch dumps etc? because RACE CAR!!! :-P Report
September 1, 201214 yr comment_624450 because RACE CAR!!! :-P No man it's a V8 so it's, because tow car!!! Report
September 1, 201214 yr comment_624453 Personally i've never had any issue's changing gears, and i'm pretty sure your gearbox will cost more than my entire car but, props anyway if you're going all out Report
September 1, 201214 yr comment_624461 LOL, you pay for something that won't munch itself with the torque output of the engine but in saying that, the 33 ate the old dog box that was in it. Report
September 1, 201214 yr comment_624466 ^ There's lots of cars that run turbo LS motors with a stock box and handle it fine Report
September 1, 201214 yr comment_624473 ^ There's lots of cars that run turbo LS motors with a stock box and handle it fine I know of a VE R8 turbo. Has gone through like 5 gearboxes. Apparently they're fine on the stock motor but once you start upping the power, they're garbage. Apparently. Report
September 1, 201214 yr comment_624479 You've got to think though, a lot of driveline stress is relative to weight and punishment, Dropping 1 tonne from a VE is a lot less stress and there's a massive difference in stress running say 15x8's compared to 20x12's or whatever, and once again mechanical sympathy. Not saying the gearbox isn't needed it's up to you really but for $8k on a box alone i was thinking there'd have to be a very good reason, and that reason was what i was curious about Report
September 2, 201214 yr comment_624513 It's a racecar, why would you want to use a clutch to change gears, so much time is wasted doing so. Report
September 2, 201214 yr comment_624516 May as well buy a sweet gearbox for it. Id have one if I could, and with this engine you can take advantage of one of the 100 or so ex v8 supercar trannys that are for sale at the moment, for an eighth of its new price. Report
September 2, 201214 yr comment_624519 Why is everyone constantly hating on this build? LOL Sure you can run a stock box, but why use a clutch to change gears when all it does is cost you time and increase the chance of driver error? Also this box through racing conditions in the Ksev should last forever! Edited September 2, 201214 yr by Subaru_kid Report
September 2, 201214 yr comment_624525 Not to mention that it was probably a spare one from the shop so who gives a toot. Report
September 2, 201214 yr Author comment_624583 it was one just on the shelf.. and a stock box would be fine but i want to go fast and a dogbox saving massive time on gearchanges why would i go t56.. not to mention there is no room for headers with the stock box and starter location with this setup the starter comes in from the back and the clutch and flywheel is 5.5" round!! super low enertia and makes you go faster without trying :) Report
