December 14, 201312 yr Author comment_673569 Just got my new Genuine Aisin Brake master cylinder in the post. Pretty stoked with that. Report
December 21, 201312 yr comment_674048 If you don't mind me asking, what transmission and bell housing did you use? Also where were you able to acquire the throw out bearing? P.S. car looks amazing. love this project Edited December 21, 201312 yr by innovativetC Report
December 21, 201312 yr comment_674052 I only saw the bit about the Y and S bell housings and the w57 transmission. 42 long pages is a lot of reading haha Report
December 21, 201312 yr comment_674053 I see now. you used the w57 with the y bell housing. What transmission is that bell housing from though? Here in the U.S. I've never heard of that. Report
December 21, 201312 yr Author comment_674054 Its a gutless commercial engine from a van or hilux that uses the w or g5x gearbox. Report
January 11, 201412 yr Author comment_675246 Thanks mate. With no car at home to work on right now, I've taken some time to polish up the engine covers for some extra visual appeal. Since the front engine cover is no longer used to mount the engine, I die ground the ribs away from the mounting boss and smoothed it over. Its all polished out and cleans up the look of the cover. I still have the three holes there if I ever wanted to mount anything there. What you reckon? This was done by first filing and die grinding the casting dags away, hitting it with an orbital sander with 80, then 150 then 320 grit paper, then buffing with with 800, then 1000, then 2000 wet n dry. Then a final rub over with a green sourer pad and then buffed with compound on and 8 inch polishing wheel. Stage 1 wheel coarse rag and mild wax compound, then the fine calico cloth and the fine compound. The front cover took about 6 hours all up, the top I spent about an hour on, I was better at it by then. Considering the minimal equipment needed and that it only costs time, presenting something like this should be mandatory! Top Cover Before: Top Cover after: Front cover polished with ribs machined away: Report
January 22, 201412 yr comment_676007 Man, this is looking.. Amazing :o ! Must pop around one day and see it in the flesh :) Report
January 22, 201412 yr Author comment_676011 Yeah I'm still waiting for it to come home from the shop. Getting toey to have her back! Report
January 23, 201412 yr comment_676021 Looks like a bonds cage there, not quite as bolt in as advertised but a few tricks later they go in... well made though. Report
March 4, 201412 yr Author comment_678784 Just had word that my car is being finished off at the moment at the shop. Should have it back in a week or two with the full exhaust, cage, mod plates, tailshaft, boot floor repaired and all the rust gone. I'm so ʞ©$ɟing excited! I have bought a pair of side skirts for it as well, as I intend to run a lip and it will bring it down to a similar level, plus I think 86s' look naked without them. Report
March 4, 201412 yr comment_678826 This is excellent news, am looking forward to seeing the results. In regards to both performance & aesthetics. :yes: Report
