Spencer[RL] Posted January 18, 2012 Report Share Posted January 18, 2012 (edited) Normally 4 inlets/outlets on a surge tank . Top - over flow Mid top - return from rail Mid low - from tank Bottom - To rail With Big pump feeding Surge tank, and small pump feeing to rail. Also going to need fuel filter before Big pump and before Small pump Edited January 18, 2012 by Spencer Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 18, 2012 Author Report Share Posted January 18, 2012 (edited) Sooo, basically a fishtank? Why couldnt your return go to the fuel tank? Or is that just optional Already have a fuel filter before pump under car and one in the engine bay. Edited January 18, 2012 by B.L.Z.BUB Quote Link to comment Share on other sites More sharing options...
Spencer[RL] Posted January 18, 2012 Report Share Posted January 18, 2012 It can , Unnecessarily plumbing tho Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 18, 2012 Author Report Share Posted January 18, 2012 It can , Unnecessarily plumbing tho Not if you are running original fuel lines. All id have to do is plug the return on the surge tank, yeah? Find the hose to the pump i have and run it to the second pump to the surge run a new one fro surge to the Walbro and an overflow return. Seems pretty basic. Quote Link to comment Share on other sites More sharing options...
Ella Posted January 18, 2012 Report Share Posted January 18, 2012 part of the way the surge tank works hinges on that return at the top of the surge tank reed. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 18, 2012 Author Report Share Posted January 18, 2012 Why, does it keep the whole fuel system at a constant pressure? That makes sense Quote Link to comment Share on other sites More sharing options...
Ella Posted January 18, 2012 Report Share Posted January 18, 2012 yes and any air that gets in the tank is pushed back out into the return to the tank as its at the top Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 18, 2012 Author Report Share Posted January 18, 2012 Damn. I need a surge tank :( Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted January 18, 2012 Report Share Posted January 18, 2012 (edited) You can return to either, the only probelem is that the lift pump has to be much larger if you return to the tank, as it literally has to supply more than the pressure pump. If you return to the surge tank your lift pump can be quite small, as it only has to supply slightly more fuel than your car is actually using at any given time. The advantage to returning to your tank is a supply of cooler fuel, as it has not been circulated to your engine and through your fuel rail 20 times while waiting to be used. Although this is hardly relevent in most situations. Either way you still need an overflow from your surge tank back to the fuel tank. Edited January 18, 2012 by oh what a nissan feeling! 1 Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 18, 2012 Author Report Share Posted January 18, 2012 You can return to either, the only probelem is that the lift pump has to be much larger if you return to the tank, as it literally has to supply more than the pressure pump. If you return to the surge tank your lift pump can be quite small, as it only has to supply slightly more fuel than your car is actually using at any given time. The advantage to returning to your tank is a supply of cooler fuel, as it has not been circulated to your engine and through your fuel rail 20 times while waiting to be used. Although this is hardly relevent in most situations. Either way you still need an overflow from your surge tank back to the fuel tank. Great explanation Matt. Appreciated. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 19, 2012 Author Report Share Posted January 19, 2012 A few pics. Painted the cable mount too. Trying to sell my head unit and amp to fund a surge tank setup Quote Link to comment Share on other sites More sharing options...
Spencer[RL] Posted January 19, 2012 Report Share Posted January 19, 2012 Sex , liking the black strip on the lower doors . Those exhaus pipes looks silly Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 19, 2012 Author Report Share Posted January 19, 2012 (edited) Those exhaus pipes looks silly Yeah Ive been meaning to shorten them to make it less 'hektik drift uleh' but it keeps breaking so I have to fix it and have no time for those things ha ha Ill cut em off before the upwards bend Shhhh, I have started to like the slant front... Edited January 19, 2012 by B.L.Z.BUB Quote Link to comment Share on other sites More sharing options...
01sik Posted January 19, 2012 Report Share Posted January 19, 2012 +1 for slanties Quote Link to comment Share on other sites More sharing options...
chrisfindlay Posted January 19, 2012 Report Share Posted January 19, 2012 you should just take the exhaust from cop bait ;) and leave me with your exhaust and leave with some money :) Quote Link to comment Share on other sites More sharing options...
