OK new issue.
Now its running sweet (most of the time) when I go around corners, or come to a complete stop and try to go, it stops and starts, cough, splutter.
My car doesnt have a surge tank.
Would this be the issue, though I never had an issue like this before my last fix.
Is a surge tank 100% necessary?
This may seem like a stupid question I know but all I need is a Y or N.
/\/\/\/\ your comment is extremely valid....take heed of this EPIC advice :)
as long as the 100 shot of nitrous doesnt blow the welds on the intake :):):):)
Edited by madKE35coupe
Seen the Nos bottle for sale ?
Yeah I was thinking the same thing.
No more fish tanks just an answer please. fishtanks after.
Edited by B.L.Z.BUB
Yeah its just weird how it has only started happening now.
I'm pretty confident all my rewiring was solid. The fuel pump is cranking.
I just filled it to the brim with fuel and it seemed to go away after about 5 minutes of driving (I'm assuming the air bubbles worked their way out).
Maybe after my fixing its running better therefore the lack of good uninterrupted fuel pressure is more noticeable?
Was it shitting itself on low tank of fuel ??
When cornering fuel slosh's around and distrupts the constent pick up of fuel needed for efi.
Yeah I understand that, but it also happens when I come to a stop. then go.
Fuel wasnt seriously low, maybe a 1/4 tank.
Do you know what fuel pump it has? I know when some people do the 4age conversion they mod an ae82 pump to fit, and they don't sit low enough in the tank so they start to get issues when the petrol gets low.
Walbro external mounted under the drivers side rear passenger seat.
I suppose I can just see if the problem returns on a low tank.
I thought surge tanks on the *e7* conversion was just to be fully hektik for mad skids.
Wasnt sure if was actually a necessary component for daily (enthusiastic) driving
Before my fixes I drove it till it was almost fumes without an issue.
Edited by B.L.Z.BUB
Pretty sure its the one pump under the car Matt.
I'm assuming you use a pump to the surge tank that pumps slightly more than the main pump therefor the surge is always full?
With the obvious return lines etc
Or something like that?
Edited by B.L.Z.BUB
