Coverting To Power Steering On 4kc Engine
I am looking ito converting the manual steering of a toyota with a 4KC engine into a power steering one.
Has anybody done this?
What car (model or make) was your "donor" for the whole set-up to do it successfully?
^^^^^ :D
I considered the same thing but after a while realised i didnt really need it cause they're only a light car :y: Would be interesting to see if anyone has actually done it though! Was that an option on the hachis???? Maybe it'd be interchangable if it was :(
you don't need power steering ? what ever happened to that thing called *feeling / responce of the road ?*
Was an option on the JDM AE86's yes
Thought i'd read somewhere that it was an option :D I'm with the others though.....better off spending your time & money on something else imo :y:
I feel for you with the Kingswood without power steering.
I actually removed the power steering from my HZ as it was WAY to light (and pissing out oil). Didn't have any problems even with 235's on the front with a sports sterring wheel.
I agree with the sentiment that all of the other guys have expressed, however......
The JDM sprinters had PS as an option, as did I beleive, the AW11's. These racks are the same/similar as the sprinter and KE70 ones. You would be on your own with the pump setup, but it couldn't be too hard.
Cheers, Ian
JDM AE70-E, you could get PWS(was rack and pinion), TE70 also(steering box)
there were only 2 in the 70 range.
if you really need PWS, try getting the steering column out of a suzuki ignis, they have electric PWS. cool setup.
Edited by TRD ke70
  • 2 years later...
sorry to revive a very very old post... but i have just started with this PS conversion.
the PS rack and pinion above is of unknown origin... i haven't been able to find a stock TE70 or AE86 PS rack and pinion locally (here in Philippines).
as for the pump and pump bracket, I am using the PS pump from a 7K engine (coming from a locally available toyota utility vehicle called REVO).
the unit have yet to run :poke:
