All Activity
This stream auto-updates
  1. Yesterday
  2. Such an angry beast. Your dog was excited. Probably wants to go for a ride and hang out the window. There's a guy round my way who takes his dog out for drives so he can hang out of the sunroof.
  3. I have discovered this is only an issue if on a laptop/desktop computer. Working normally if I access the site via my mobile phone
  4. GJM85 started following Gjm85'S Ke20 Build
  5. Do we know why the message function doesn't work? Possibly a systems permission error? Been happening for a while now
  6. It's still alive... ish. https://youtu.be/ErpP_xxPf_8
  7. In this episode, I've had the buckled wheel replaced and the wheel alignment done. Happy with the car except for this annoying squeak coming from under the car at idle when the engine is hot. I'd convinced myself it was either the belt, the tensioner or the water pump so I replaced all three. In the process of removing the alternator, I shorted the 12v cable because I'm dickhead and didn't disconnect the battery first. Total amateur.... I exploded the 120amp ALT fuse and oh my fuck it is a bastard to replace. You have to dismantle the entire fuse box to get to the 10mm bolts that hold that fuse in. Toyota's punishment for committing a mechanical sin. Moving on, I haven't fixed the squeak. I've narrowed it down to the spring loaded exhaust bolts between the shitty exhaust manifold and the catalytic convertor or there is an exhaust leak that union. Likely caused by jacking the engine up and down when I replaced the gearbox. I'll live with this for a bit till I decide if I'm going to change the exhaust system, or save for a turbo kit. That would be exciting if a tad bit out of my price range atm. I ordered a rear torsion bar from TTCR-II on Ali Express. It took about 6 weeks on the slow boat and arrived yesterday. I didn't have high hopes but I'm not disappointed. Its steel mounts and an aluminium bar with vulcanised rubber bushings. All nuts and bolts included, with the exception being that main bolt through the bushing. The kit came with 8mm bolts to fit in a 1/2" hole. No good Gary. So off to Simmo's Industrial Supplies, this morning, for the right size bolts and lock nuts. 9 eddies later and I'm really quite impressed. Installation involved disconnecting the shocks and lowering the rear beam to remove the springs. All the holes lined up. The rear spring needs to be rotated in its seat to a point where the lower coil clears the mounting bolts. Otherwise very straight forward install. 15 minute wet test drive and the car feels noticeably more stable with significantly less body roll. I'm honestly very satisfied with this purchase. I think Super Pro trailing arm bushes and decent set of shocks will finish the rear end off nicely. Unitl next time....
  8. Recently returned from an oversea trip with a 10 day spell in Japan. Had been about 11 yrs since I was last there with my young daughter, no Disneyland this time. The car related highlights were seeing an AE86 driving down a street within minutes of arriving in Tokyo - I heard it first. Never realised how quiet most modern cars are. Rocking up to Takayuki’s house (TH Service) in Tokyo to spend up on a “few” parts. Such a lovely guy. Then the Toyota museum in Nagoya where they must have known I was coming as they laid on a TE27 in the foyer. But the best was in Osaka. I had been wandering around Nihonbashi looking for vintage electronics when I stumbled across a tiny corner workshop. So tiny you would only get a tiny car (i.e 60/70s) in there. And that tiny car was a Honda S800. The old bloke was tuning it and it sounded glorious! A throw back to a different era. He even had an oscilloscope.
  9. Last week
  10. Close to Orange in NSW? There's a few KE70s a the local wrecker that will have looms, but it would take quite some time to extract them.
  11. Hi guys new to the forum hope its still alive and well in here, unfortunately I come begging tho, I am looking to buy a dash wiring loom including interior fuse box for my 82 ke70 corolla if anyone can help me out
  12. John_groome joined the community
  13. Earlier
  14. Crazy_Doo43 joined the community
  15. hino83 joined the community
  16. Good to know I am looking at rejetting my 32/36 weber, how far is your idle mixture screw turned out and how far is your idle speed scew turned out if you do not mind me asking.
  17. The sills were getting chipped of paint after 40years, so I thought I'd give them a more modern coating than the black tar they usually supply in aerosols. I sanded them back and undercoated them, then sprayed them with MIPA, a urethane stone-chip protector. Two coats covered them well, but not as smooth as I hoped. Still, another undercoat and a couple of topcoats and they look like new- Not cheap, the two aerosol cans of paint were over $100, the MIPA a bit less. The paint shop tells me the light blue is no longer available in acrylic aerosols, hence the price for a two-pack. Even with a mask on it hammers your lungs, so I won't be using it again.
  18. So I started the new patch panel in the same manner as always. Start with cardboard template Then make it out of something a little harder, and start fettling. For some reason my fettling is taking a very long time. i had to manually put the bend in, so i used the handle of a hammer but i put it in the wrong spot. So straighten and realign. then bending the corners I just lost focus and they are a little wonky but nothing some time with a hammer can’t fix. So after a good while I feel like I’m getting close. With the brace held back in place with clamps things seem to mostly line up at the back. Then looking from the front I am fairly close, I still need to trim off the extra material I left but I will continue to fettle
  19. 4LpHaT34m joined the community
  20. That email appeared this morning! No problem, I have that figured out, and now I can see its a change that is beyond Rollaclub's control.
  21. Isfahan joined the community
  22. I've emailed you on the address you registered with a couple of days ago but you haven't replied so guessing it isn't one you use now. Unfortunately the forum message system doesn't seem to be working anymore either. i'm not a proper mod so can't comment on the changes. I was overseas when prompted to login myself and thought it might have been something dodgy - so waited till i was back at home.
  23. Awesome! Thank you, Altezza! Hopefully I can get this car to what I envision it being one day! It will be a while until that happens, but I want to make sure I'm taking the best first steps to get there!
  24. It would be hard to find one without rust these days, that's pretty good compared to most. Pull the hatch seal rubber off and check the seam joins under it, the boot seal is a favourite place for rust in the sedans. If you want it showy with lots of negative camber then get the longer LCAs. Old Mitsi Sigmas are even longer than Coronas. The LCAs will have negative angle on them (crossmember lower than the wheel hubs) when you look from the front if you lower it enough, which is why people buy blocks to put between the LCA and the strut. Too low upsets the steering ratios and will be hard on tyres, but great for looks. Pull out the bump stop if there is one above the diff, put a pair on the shock rods instead. Check for the exhaust hitting the axle as it goes over it with the 3" lowering blocks. When its all done and dusted next year, put up the wheel alignment figures!
  25. Interesting how much difference there can be between model numbers, especially when the compliance plate doesn’t clearly identify the model. German cars can definitely be tricky to work on sometimes!
  26. Thank you so much for the reply! To answer your question, this car will be mostly a show car that I can get out occasionally to ride around town and maybe drive to a car show....not a daily driver at all. Probably not even a track/drift car. The body is in pretty good shape, but not flawless by any means. There are a couple of rust spots on the panels that I need to figure out what to do with, either cut out the rust and patch with a weld-in patch or maybe some spots aren't as bad that I can sand down and fill in. So you're saying I can scrap the LCA's? I like that! Saves me some money! It does need some transmission work, as the bearings sound like they are going out. I have a rebuild kit; the next weekend I'm free, I'm going to pull the transmission and install it. Here are some pics of the car as I got it. Sorry, they aren't the best; I have it kind of tucked away in my shop right now with the wheels off. I was showing my son the parts of the car and teach him what I know.
  27. Have a look at the distance between the diff and the bump stop above it, and think about how much movement you want the car to have when you ride over a bump. That will be with an empty car I expect, and you won't be carrying anything in it when its lowered. What you decide for ride height will give you the comfort and the handling, because it will hit the bump stop with a back-bruising 'whack' and instantly transmit the weight of the car to the tyre sidewalls, who usually give up and the car jumps sideways. Buy the 3" lowering kit but start with some home-made steel boxes half that and see what happens. Run your coilovers with stock LCAs first, just use a spirit level to measure camber at home, and check how much tie-rod end thread is used. Using longer LCAs will give increasing camber and mean less and less thread holds the steering arms in. This was my KE70 on stock 175/70 tyres with just cut rear springs. ...and this is with BCR weld-on coilovers, their rear springs and 185/70 tyres on 14" rims. That car does 80km a day through countryside on B-grade roads so I need suspension that works well. The BCR rears were too hard so I went back to the stock springs and kept the BCR adjustable shocks. If your wagon is just a show pony for occasional track days you can go lower. What about sway bars? I run a stock front and an upgraded Celica rear. You might not need that much extra as the leaf springs will not have the grip of the 5-link. Is the rest of the body in good condition?
  28. Hey all! I hope there's enough people here still to give me some advice. I just bought a 1983 Corolla Wagon that I plan on modifying to my liking, but I wanted someone to look over my parts list for lowering the car before I start buying things. I did my research in the KE70 Lowering thread, and I think I have a decent understanding of the parts I need. I was just hoping someone who has done the work can give me advice on whether or not these parts are correct. Front: Original Strut Housings and top mounts Technotoytuning Weld-on Coilover kit AW11 MR2 Rear Struts Ae86 LCAs Celica Wheels Wheel Spacers Rear: 3” Rear Leaf Spring Lowering Block Kit I've never done suspension work like this on my own, so this is all new to me. I bought this car as a vessel to learn how to work on cars, body work, suspension, engine work etc.. Any help is greatly appreciated!
  29. MrObakemono joined the community
  30. JWF 439 NW joined the community
  31. Philemon joined the community
  32. Hi all, I am looking for a replacement bonnet for a KE20 i am working on. Thought I had sourced one from a supplier in Pakistan but looks like I have been ripped off. Does anyone have one knocking around in good nick that they would be willing to sell and ship to the UK for me?
  33. TE27Fan started following KE20 Bonnet
  34. TE27Fan joined the community
  35. Well life got in the way for a while, after losing both my parents I kind of lost motivation and many a project stopped. But I’ve decided to take a sabbatical from work and focus on the family and getting back to my old self. So that means… getting back to the front fender. When I left off I had removed the inner brace as when I cut out the slab rust patch I could see there was much rust back there. So I took the strip wheel to the brace and found some pin holes that also needed mending. And the top of the brace had rusted so that got some treatment too But after looking at the bottom section of the fender I think I will just cut the bottom off and remake it. It’s heavily corroded and the 0.8mm steel will be paper thin by the time I clean it up
  36. I'm always wary of those videos, there are tonnes of similar ones out there for just about every type of product on the market (from cars to olive oil), and you just know they are full of AI slop and dubious/fake information. Not saying that there isn't truth buried in there, but the claims are often just vague enough to avoid being libelous or to hide where exactly the details have come from (if they have come from anywhere other than thin air). For instance, the fact that at about 19 minutes in the video talks about "this isn't some 15yo engine on a badge that has left Australia, this is on a dealer forecourt in Blacktown, right now" talking about the Ford 3.0L TDV6, yet the pictures are of a Honda CRV (yes, I know the voiceover is being rhetorical, but it just goes to show how much effort is actually placed in to these videos). Another sign that it's AI text-to-voice is when they call the Ford 2.0L TD the "ee sea oh blue" rather than "Eco Blue". The thumbnails are always click-baity (usually with a screenshot of a news reader next to something on fire or a big red scary graph). Every video sounds the same, looks the same which shows that they're just pumped out with little to no human interaction, let alone someone real actually saying the words and appearing on camera (it's always short snippets without audio from other online videos or news stories)
  37. Sounds like a job for Banjo... You will need to know what the Defi gauge voltage should be, and what is arriving at the gauge. I have the opposite problem- since I converted to coil-over-plug there is no coil to produce the pulse for the factory tacho, and the Haltech fires the coils with only 5V. The tacho reads at idle, but not above... I need to fit an amplifier to make the 5V pulse larger, I'm not sure what your one needs, unless the gauge is expecting a lower voltage than what it is getting. Also, check the gauge for options on cylinder numbers, you can often set them for 2 or 4 or 6, 8 cyls and it divides the pulses to suit.
  38. Hello guys, currently going good on my ke30 restoration. Installed a 3 gauges defi A1 setup on my ke30, the rpm gauge is accurate on idle but whenever i rev it, even tiny revs, it goes up uncontrollably, up to 7K even hahaha. my coil and dizzy setup: 12v original spec coil with an electronic dizzy
