iwontarolla
Everything posted by iwontarolla
  1. So i have a ae71 tacho dash, i'm going to put it in my ke70 panel van. but none of the plugs line up, I've found a guide on toymod http://www.toymods.org.au/forums/tech-conversions/568-ke70-panel-van-dash.html still kinda can't get my head around it. any help would be great, i still have the 4k in my pano as well. thanks chris
  2. got some photos the from the other day just of the front guards. i also went to upullit today and got a stock air filter, got home did some cutting and modifying fits pretty well. both look about the same. started off like this. cut every thing off can't seeing in this picture but yea. now looks stock
  3. http://www.rchobbyestore.com.au/p-8972-new-18-remote-control-car-rc-nitro-4wd-monster-truck.aspx is some thing like this going to last very long or not? just want some thing to bash around with.
  4. i have ordered a seat belt from repco should be here some time this week. i also changed my washer bottle, started making those changes coming along good so far. front guards are also almost done, then its just time to do the rear guards. i also wanna run a lsd soonish but don't know how i want to do it. i also toke it for a burn up and down my road. it seems to go pretty well, but doing 70 in 3 if you put your foot down it kinda lags then picks up the revs and goes. i don't know if this is due to the lack of exhaust and bad tune or the cam?
  5. if your over 25 and on your P's you can drive any thing.
  6. i used the points/ ignition module version. also changing up the design of the washer bottle. going to separate the two then weld them together getting way to much distortion. the front end is almost done as well just got alittle bit of grinding and bogging. i also painted in the inside of the drivers guard with the body deader to cover the fact i cut and welded the guards. forgot to get pictures but yea update soon. I also still need a drivers side seat belt, a stock air filter ill pay postage from any where.
  7. so i;m kinda just stressing to much? if so that's great but if it was such a problem i was going to start phase 2 on my build haha from the my license website " High-powered vehicle restrictions apply: if you are under the age of 25 until you gain your full drivers licence if you obtained your P1 or P2 licence after 4 September 2010 if you were disqualified and returned to driving on a P1 licence on or after 4 September 2010. High-powered vehicle restrictions do not apply: if you are 25 years of age or older if you obtained your P1 or P2 licence before 4 September 2010 if you have an exemption certificate. Exemptions may be approved in special circumstances by completing theApplication for Exemption from High-Powered Vehicle Restrictions. Your driving offence history, the availability of public transport and of other vehicles that may be available to you will be taken into account when determining your application. Breaking the rules The penalty for driving a high-powered vehicle includes paying an expiation fine and you will incur demerit points. High-powered vehicles A high powered vehicle is a light vehicle with a Gross Vehicle Mass of less than 4500 kgs that has: 8 or more cylinders a turbocharged or supercharged engines(except diesel powered vehicles with less than 8 cylinders) been modified to increase engine performance (link to vehicle modifications section below) been nominated high performance vehicles - refer to the list of Included Vehicles in the High-powered vehicles notice below. Excluded vehicles - vehicles listed under the list of Vehicles Excluded in the High-powered vehicles notice below have turbo charged or supercharged engines for fuel efficiency improvements and therefore are not classifiied as high performance vehicles. High-powered vehicles notice (PDF 65Kb) (updated 12 May 2011) Vehicle modifications to increase engine performance High-powered vehicle restrictions apply to vehicles that have been modified to increase engine performance. The following information may help to determine the type of modifcations that may be included in this defiinition but may not be exhaustive and should not be taken as a precise interpretation of the law. Vehicle attributes include: Induction system Fuel system Engine Exhaust system Note: under no circumstances should any of the above be modified or replaced with parts or components unapproved by the vehicle manufacturer, unless it is deemed essential during routine maintenance or failure rectification, see examples below: Essential modifications There may be instances when something fails during the course of its operational life. In these instances the affected parts or systems will need to be modified. Examples: Allowed An engine cylinder head with a damaged head gasket will require skimming and the intake and exhaust valves potentially replaced or re-seated. In this instance the cylinder head may be skimmed to the minimum required to provide a flat surface for sealing purposes only, and if valves are replaced they must be of the same diameter and shape as the original part. Camshafts can wear out prematurely if the lubrication system fails or the incorrect engine oil is used. They may be replaced with original camshafts from the vehicle manufacturer or camshaft that have the same profile i.e. lift and duration as the original design for that vehicle. Prohibited Any unnecessary removal or polishing of material either from the cylinder head sealing surface or intake and/or exhaust tracks. Camshafts that have a higher lift, longer duration (aggressive profile) than the original fitted to the vehicle at the time of manufacture. Any modifications to the vehicles computer system with regards to airflow rates, fuel delivery rates or ignition timing etc. Essential replacements There may be instances when something fails during the course of its operational life. In these instances the affected part or system will need to be replaced. If a non-original (aftermarket) part is used then it must be a direct replacement for the original and designed to fit within the current housing and/or mounting system and operate within the vehicle manufacturer’s specifications. Examples: Allowed An exhaust system that is corroded beyond repair must be replaced with either a new original replacement from the vehicle manufacturer or an equivalent non-original (aftermarket) system that meets approval standards for emissions and noise. Replacing the air filter with a non-original (aftermarket) equivalent is acceptable as long as designed to be a direct replacement and fits correctly within the original air filter housing. Prohibited Free flow extractors and/or mufflers and/or the removal of the catalyst (if originally fitted with one). Any type of induction kit that will increase airflow to the engine above that of the original system. Replacing the vehicle's computer system with anything other than the original specified by the vehicle manufacturer for that engine. "
  8. well that's the plain with the weber put a stock filter on. but i don't know how to get around the exhaust any cop that is out to get there quota will get me on it.
  9. hey guys, so i was reading up on the p plate laws. my ke has extractors and a 32/36 this is a breach in the laws. I'm kinda stressing about if i drive it and get pulled over and they see i have these i will most likely lose demerit points. and then i don't get my full license until I'm like 21 or some thing. am i stressing to much? i was thinking about trying to get a exemption but i don't see that happening. any help, info or suggestions would be great thanks
  10. would you mind just making a little diagram of how you have yours wired up?
  11. what do you mean by igniter? is that the coil driver? wiht the insulated cable do you mean connects the coil diver and all that or what? thanks for the info
  12. so i went to Elizabeth and gillman upullits today. Elizabeth was a was of time expect i found some things that i had to hide around the yards for next time. but the best find of the day was a baby blue ke70 wagon at gillman. since my hatch is dented and rusted alone the bottom, i thought i would pick up this overrated one. also got the boot seal as well. it was in great condition defiantly a upgrade to the torn one. also got a pretty overrated garnish thingy with the number plate lights in. just needs a polish and a paint and its ready to go. got parts to fix the lock on the back as well.
  13. yea it was from a place in Brisbane. it has been sent back today to get a full refund. will be buying probably of tunersgroup
  14. will send you a inbox now. I'm figuring out how much it is from tuner group as they are $379 pull postage I'm guessing. ill hit you up if you are cheaper. i have contacted nardi and have told them about this issue. so see what they say once they reply.
  15. got it off ebay inbox for sellers name. parrot- was just about to send them a email, things like this that make it hard for nardi to do there thing.
  16. yea but i think on the cover bits they are glued. but every thing about this one is just dodgy. worse part i have to pay postage to return it. any one know a good place to get a real one?
  17. well i payed 350 and got this sh*t, I'm not happy one bit. do you guys think its fake? I'm sending it back either way.
  18. hey guys i bought this a couple of days it turned up today. i will not say who or where i got it off until it is claimed it is fake. let me know what you think, i think its fake and if its real i am not please with the quality of it. thanks guys
  19. finished off the hand controller for ignition. now i just got to figure out how to wire it up what coil i need and then ignition curve. if any one can help out with any of these it would be great. i also sanded back the bonnet got rid of the horrible camo bonnet, and started fixing some dents in it. all the supports have broken lose how would i glue these back to the bonnet skin? also working on the guards still, passenger side guard is all most up to being bogged. driver side is all most done. thanks guys.
  20. Thought they would be jdm. Where is this 2022 or 2014 stamped?
  21. Hey guys, I'm trying to figure out what brakes I have, done some seat searching. Umm guessing they are ae86 but are they adm or jdm or what. Thanks guys
  22. nahh all good. yea if you wont one, i don't know how much it would cost depending on gas. but if you like the finished product we can go from there. or even if you know how to tig weld i can get every thing cut out and you can weld it?
  23. I'm kinda using it as a learning tool, and this is just like the stock one so its washer and radiator overflow. It should look pretty neat when its done as well.
  24. i got stuck in to the washer bottle tonight. i linished all the pieces ready to be welded. its a little tricky tacking every thing together as 316 is nonmagnetic. this lead to a few tack welds not joining and burning slight holes. but once i got the hang of it it started working out fine. there's also a few spots that don't line up and are gaps. if i make another one i will have to change a few things for it to work. ill also have to work out some sort of jig to make it a tad easier. also when i first started tacking it together i didnt set it up to well so i blow a few tack welds but i have it all sorted now.
  25. your cars amazing mate, couldn't stop looking at it. was flipping through your feature back and forth for ages. great work :y:
