Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. Whats wrong with this picture...... Does a 3 year old do your machining?
  2. ....and the bigger is for a K-T50. :wink: Long story short - Yes you can use the ke30 flywheel/clutch with a ke70 4 or 5 speed.
  3. So is this in a KE70? If so you probably have a ke55 style water pump. Flick $20 my way to cover postage and I'll send you a ke55 style pulley in an express bag. :wink:
  4. My wheels will be for sale soon
  5. Bit hard to say without hearing it, could be. Does it sound like a bearing or something rubbing? Did you machine the flywheel when you put the exedy in?
  6. Probably not. 4k has all the anti-pollution stuff hanging off it and 3k doesn't.
  7. Welcome! The cracked piston would make me wonder if anything has been done about retarding timing?
  8. Mine is 5k bottom end 3kbp head. Mitch is doing a arp head bolt group buy at the moment. t25g will do 15psi but the shaft won't really appreciate 20, need ball bearing for that.
  9. Probably just a worn input shaft bearing in the gearbox
  10. No worries. Btw there was a couple of manifold issues I was going to for warn you about! Might pay to give me a call again and we'll talk about the cas and turbo too. ;)
  11. Have a read of "how to build a tough k motor" in the faq ;)
  12. Do you want to borrow my k cas? I've got no plans to use it any time soon, but would like to give it a try one day. Then you can also work out the pin out for me! Lol
  13. What are you using for a pickup?
  14. Now it is a rides thread! :wink:
  15. Probably a better idea
  16. Looks like it's all 1 piece!
  17. I'm keen to try it out, re shaft speed convo. Talk about it soon. ;)
  18. Yeah I saw that coming into town on a flat bed. Nearly snapped my neck!
  19. Oh... This is a build thread is it? Given you started it in general mechanical I just assumed you were actually open to help from people that have done this all before! My bad, I'll move the thread to the rides section in the morning. Cheers, Si.
  20. Hey buddy, too long! Good to hear it'll be back on the road soon. Funny you should quote that post from ages ago, this guy needs to read it! He wouldn't have even got as far as a/r's yet.
  21. Lift pump?
  22. He's got one of those 80amp VL jobbies so I reckon that'll be the cause!
  23. What rpm have u got at idle? My fw would be the light and my belt never squeals. It most likely the massive alternator!
  24. 5k is 200mm ;)
