towe001
Senior Member
    2563
    10
Everything posted by towe001
  1. $375 a week :( yeah not bad not bad at all. A bit better then our place but we have five beds and a super sized living room (give take about the size of a 4 bay garage) And my OMG is that we only pay about $1000 for this piece of luxury.... Every six months :)
  2. So is rubber and paper and cellotape At least bubble gum is still ok....
  3. Stupid radio controls. If i wasn't careful while turning the wheel i'd change radio stations or mute the volume. Stupid barina I've seen Kuhmo, Bridgestone, Michelin, Goodyear but Double happiness ? Its a regroovable tire and each axle on the b-double had them Sexy. I love the splats Spent most of the afternoon hoping for the likes of NQX or one of the other big trucks to want to come in and nine times out of ten they'll reverse in. The gateway is roughly two and a half cars wide
  4. Maybe the turbo ae112. Its about the only factory turbo that i know of
  5. 1 - Yes and since your keeping it auto don't have to worry about a spigot bearing. 2 - No, don't believe so
  6. Had a look in my aquarium on monday morning to see how everything's going and low and behold i spot a little fish swimming around :(. As tank companions i've got three stupid guppies, two male and a female, had an idea for a few days that the female was pregnant. And from the other end of the tank a little voice from my daughter pipes up "Oh, look, baby fish". Rough counting put them at around 20 of the little phuckers :) Spent the day at work thinking of what to do with them...... ditch them down the toilet ?? Give them to the cat ?? Got home and realized that the girlfriend's Siamese Fighting Fish likes live food :D wonder how it'd go with the babies. The thing goes nuts when i dump a few of them in the tank with him. Found a good reason to keep the babies and the stupid guppies now :)
  7. When KE30_KE35_KE55 said about a flat board to sand with he wasn't far from the right idea. What you need is a board of around 400mm long and about 45mm wide, firm but soft enough to form to the shape of the body your sanding back. Their either called a "speed file board" or a "longboard". Some have a thin (5mm or so) stripe of foam running the length of the board, some don't. Might be able to make your own from a length of the plastic type cutting board found in most kitchens. A sanding block is good for general sanding back etc but not so good in what your wanting to do in filling in the low spots and knocking off the highs, a longboard would be a better idea. The longboard "floats" over the top of the low spots missing them knocking down the highs where as the sanding block will fall into the lows and "run up" the highs.
  8. It wasn't a holden barina was it ?? The one we had, we dreaded having to open the boot cause of having to almost jump on the lid to close the thing. SLAM - nope didn't work SLAM - nope still didn't work SLAM - what the.... SSSSSLLAM - yep that got the phucker Sounds like stupidity on the passenger's behalf. But then again i once knew someone that if they wanted to drive.... and then it was my fault for letting them drive in the situation they wanted to drive in, in the first place Not i said the tow
  9. Irwin Bolt Extractor for the win if the head is rounded off http://www.irwin.com/irwin/consumer/jhtml/...IrwinProd100512 Metrinch is good but not that good - not good for tight areas and i've had them slip off and also start rounding off heads
  10. When i got to work the first thing up i had to do was move some 25 litre drums, i throw what i thought was my back out. At first i thought it was a muscle on my right side just under my ribs. Got home after work and asked the other-half to give me a massage and low and behold she started digging and rubbing my right side and i almost went through the roof when she put the lower rib back in place and started working on a muscle
  11. Rolla'boy - don't take it the wrong way or anything, but your sister's not manic depressive is she ? Just asking cause she sounds like an ex-girlfriend of mine who would do the same thing not just to me but her mum, uncle, friends.
  12. I had an old school mate who's father was like that - an alright guy but get him in a bad mood..... WGMG or more like annoyed - I want some planting tongs for my aquarium and a few other things as well. But i'm not prepared to pay though the nose for the tongs and then have to go else where for the other stuff. All cause the aquarium shops that i like to deal with on the net don't have the tongs in stock so i'm either going to have to fork out $25 for them locally or wait so that i only have to pay about $7 for the same damn thing
  13. But have a look see first off. You should be able to figure out what you think is ok and what's a little "odd" - a typical joint operates in fairly the same fashion no matter where its located. Try with giving the joints a bit of fresh grease. If you can A continuous squeaking would be more like a suspension part thats ran dry with lube or the springs have worn out the rubber pads and are now sliding against their seats. A noise more akin to grinding would be closer to dry running wheel bearings or their running with a build up of grit. Which is not good either way. But all in all while your re-packing the joints may as well do the wheel bearings at the same time. But you'd only really be able to re-pack the joints if they have grease nipples.
  14. Jack the car up place it on chassis stands, crawl under the car and get someone to fiddle with the steering wheel while your watching the joints etc. Be a bit harder might even have better results is to do the same thing get someone to fiddle the steering wheel while your poking around the front wheels looking and feeling the joints etc.. JiP's continuous squeaking could very well be a lack of lubrication
  15. Ego tripping ? New York, London, Paris, Munich, Everybody's talkin' 'bout..... No not really i'm just seeing someone getting frustrated cause some tools not wanting to listen Same same. I tend to forget about ticking the box to move to sent messages over to the sent box, its a good idea but not so much the auto delete i'd sooner do it myself. Just noticed up in the top left corner, the quick search box. Nice idea :y: Edit - also just noticed the new layout of the forums front page, nice work :D :(
  16. Got the lancer back :y: But i had to drive the slug back home. For some reason the boot popped open and it wouldn't shut. On the way home finely had a bit of excitement from it when i took a right hander hit a few bumps and the arse end jumped out of line and started sliding a little, put my foot down a little and for once the bucket of junk had some power to pull the thing back in line.
  17. Oh so true. For a vehicle that gets total respect from da hood and yet it runs around on cart springs.
  18. You can also ask them to post out a hard copy as well. I got sick of always bringing up the pdf copy and having to scan through it just to find what i wanted so i asked for the hard copy and haven't looked back since... Urm, not long after i grabbed a pair of ke70 struts for my old chariot thinking, yeah good stuff better shocks etc etc. I found out there's two versions a 51mm and the pair i have - 45mm....
  19. When i was working at the resort there was a guy there that had a real problem with using the toilets. He'd do his turds in the showers.... Could be the same drop kick At work today i had to package up 10 cutting bits for a boring machine (i think) value of each bit was around $100 and they would have been around the size of a ten cent piece.... Re-stocking the shelving out the back and having a bit of a poke around and came across a 4" grinding wheel (finishing wheel) and it still had a price sticker on it...... $250
  20. Nope not a chance :D Found out today that my supervisor not only gets paid more then me, which i don't really mind but i would like it if he really made the effort to earn his wage. But what grinds the gears is that he not only gets rent assistance he also receives child support (about $800) each fortnight for his two kids that lives with their mum (they stay with him for about two days once or twice a month) and both him and his ex-wife received 2 grand each from the government cause of the kids
  21. A Metabo rep came into work a few weeks back and he showed us the difference between an impact driver and a rotary hammer drill on a block of concrete (about as thick as a normal house brick) - by the time the impact driver had made a dent in the block the hammer drill made the block look like soft butter. Have a look at the new ROK brand of tools - cheaper price for the same or better quality...
  22. Yep, OMG its a good feature but OMG just how dumb were they in hoping that the average slug driver would remember they've left the light switch on.... Its got a few things like that... good features let down cause of stupid thinking.. Take the "hold" button, good feature let down cause you have to reach down, way down to the handbrake, fiddle around, give up fiddling so you look down so that you can press the button again to release the brakes or what ever it is. Why not just a simple $1.50 micro switch on the throttle body ? Or at least having the button easy to get to. Good feature, stupid thinking. Kinda wondering if i should have a look under the bonnet and see what the slug is really powered by Oh yeah i miss the lancers fly-by-wire throttle control. The difference is noticeable, bit like running your hand along a silk sheet and then doing it over ,you pick the grit, sandpaper.
  23. Yeah but those lights come back on when the car is started. My dads wide body camry is the same. But the barina's stays off..
  24. Nope bugger that.... If its around my home i'll bury it, if it doesn't get away - i have kids to protect and more so the youngest will think its just a big worm. And i think the vice verse thing of being in its home - i'll steer clear of it and leave it well alone. But if it comes near my family. Sorry but its basic instinct - protect yourself/family and/or territory. Update on hire car - using the lights before, pulled into our driveway, parked, turned motor(?) off, left lights on to see what would happen, nothing, opened door, ho ho ho the lights turned off. Interesting. Down beside the slug shifter (auto) there's a button with "hold" on it - use for holding the car on the spot at, say, the lights. Leave it on and its like trying to drive with the handbrake on. Still think its a puss box but
  25. :D might be an idea. Just driving the stupid thing is a mission most days.... like trying to make a right hand turn across a busy street is almost a flip of the coin. Is that coming break big enough ?? Will this puss box be able to pick its slime up off the ground quick enough to make said break ?? Almost got written off yesterday afternoon cause of its snail power. My old ae82 twincam seca was a oh so much nicer car to drive and sit in
