A touch under 2.5Lt on the g'box.
The only part that you'll have to shift out of the road is the steering column. Two 12mm spanners at the steering box. Under the dash you'll have to shift the carpet away from the steering column which you'll find four 12mm bolts. And then its two 14mm nuts at the front of the dash where the column is bolted.
And don't forget to unplug the electricals on the column.
Onto the pedal box.
You'll need to get your head under the dash, on your back with your legs up in the air. You'll need a 12mm socket and a good light, cause a couple of the bolts are hidden away.
The only real problem i had was getting the column back through the firewall and all the bolts lined up.
I'm positive that i had a photo of where all the bolts are located on the pedal box but i'm stuffed if i can find it :(
