frosty
Everything posted by frosty
  1. frosty replied to stanza's topic in General Mechanical
    Sorry for dragging up an old thread - Tradetools here in Brisbane have advertised a 'Renegade' brand 250amp single phase, 35% duty cycle, with separate wire feeder for $1598. was in last Sundays paper. My question is - does anyone on here have one of these? Any feedback on this unit would be appreciated -- both good and bad please. Only want to buy 1 welder. Will be used for panel work and thicker steel - (probably build a trailer too) If I remember correctly, someone on here worked for one of the tool mobs - but that was a couple of years ago - are you still on here ? .. cheers frosty
  2. yep their the same as the set I've got spare pm if interested
  3. Here's a start - they make it - they can probably put you onto a retailer http://www.tycab.com.au/index.php?option=c...t&Itemid=55
  4. Cheers... but it's K10 short :worship:
  5. Thanks for the input ... will try and pull it open and have a look see Anyone got a K50 they don't need ????
  6. Arrrrhhh :jamie: 5 speed box has locked up in 3rd gear. Does anyone have an exploded view diagramme of the k50 or a workshop manual? Any suggestions on how to fix it, or what the likely cause of the lockup was?? cheers
  7. These people have exactlly what you need here
  8. Here you go , wasn't hard to type into google... so send me $10 for my trouble http://www.rego.act.gov.au/registrations/regomain.htm
  9. Here you go .... everything you need http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...n%3D4%26ps%3D42
  10. frosty replied to irokin's topic in Automotive Discussion
    Same deleted msg
  11. Thanks mate ... appreciate it :D
  12. Have KE70 , K50 box. Is there supposed to be a rubber boot covering the clutch lever arm where it goes into the bellhousing??. If so where can I get one (tried a couple of parts suppliers to no avail) Does it have a part number? ... and what is it actually called cheers
  13. Check your exhaust system - it could be vibrating on something
  14. Here's a diagramme of how the water flows in a 16v from Bill Sherwood's site Visit My Website hope that helps
  15. ???
    frosty replied to JiP's topic in QLD / Brisbane
    That's the new Busway and busway station
  16. Alot of servo's have a "rent a ute" available for about $35 a day
  17. Trev ., I'd like the info on the setup as well cheers frosty
  18. ............. He must have run out of matches :jamie:
  19. If you want to play around with ratio's etc then download this calculator http://www.locost7.info/gearcalc.php
  20. Read and then read some more http://home.clear.net.nz/pages/phil.bradsh...0into%20RWD.htm
  21. No Fuel Day Please copy and send via email to all your contacts IT HAS BEEN CALCULATED THAT IF EVERYONE IN AUSTRALIA DID NOT PURCHASE A DROP OF PETROL FOR ONE DAY AND ALL AT THE SAME TIME, THE OIL COMPANIES WOULD CHOKE ON THEIR STOCKPILES. AT THE SAME TIME IT WOULD HIT THE ENTIRE INDUSTRY WITH A NET LOSS OVER 4.6 BILLION DOLLARS WHICH AFFECTS THE BOTTOM LINES OF THE OIL COMPANIES. THEREFORE FRIDAY FEBRUARY 22nd HAS BEEN FORMALLY DECLARED ‘STICK IT UP THEIR ASS DAY’ AND THE PEOPLE OF THIS NATION SHOULD NOT BUY A SINGLE DROP OF PETROL THAT DAY. THE ONLY WAY THIS CAN BE DONE IS IF YOU FORWARD THIS E-MAIL TO AS MANY PEOPLE AS YOU CAN AND AS QUICKLYAS YOU CAN TO GET THE WORD OUT. WAITING FOR THE GOVERNMENT TO STEP IN AND CONTROL THE PRICES? IT IS NOT GOING TO HAPPEN. WHAT HAPPENED TO THE REDUCTION AND CONTROL IN PRICES THE ARAB NATIONS PROMISED LONG AGO? THE PRICES JUST KEEP GOING UP AND WE NEED TO STOP IT PETROL PRICES ARE CAUSING OTHER EFFECTS; AIRLINES ARE FORCED TO RAISE THEIR PRICES, AS ARE TRUCKING COMPANIES. THIS INCREASES PRICES ON EVERYTHING THAT IS SHIPPED. THINGS LIKE FOOD, CLOTHING, BUILDING SUPPLIES MEDICAL SUPPLIES ETC. WHO PAYS IN THE END? WE DO! WE CAN MAKE A DIFFERENCE. IF THEY DON'T GET THE MESSAGE AFTER ONE DAY, WE WILL DO IT AGAIN AND AGAIN. SO DO YOUR PART AND SPREAD THE WORD. FORWARD THIS EMAIL TO EVERYONE YOU KNOW. MARK YOUR CALENDARS AND MAKE FEBRUARY 22nd THE DAY CITIZENS OF AUSTRALIA SAY 'ENOUGH IS ENOUGH'
  22. Knight rider... baahh ... too modern I remember watching Mr Squiggle and Miss Pat ..... and it was in black and white :P http://www.abc.net.au/news/indepth/featureitems/s1451066.htm
  23. As I said in my first reply ... it's (the wire) to be attached to the low fuel warning sensor ---- yours is missing the sender unit ... see below
  24. It's the wire that would have been attached to the low fuel warning sensor thats on the bottom of the solid rod where the clip is (pic 2)
