Everything posted by SLO-030
Slo-038 + 10Psi
May have lined something up already. Not saying anymore :y: Also, on the engine front I'm toying with going the same way as TommyKE11, using quad motorcycle carbs. With a big help from toyota_ae71 i have spied on a set of GXR1100 (i think) 34mm Mikuni's for a very reasonable price. So atm its up in the air on wether to import a TE front or get these carbs. Then again, with my brain always thinking of ways to mod the wagon. I may have a killer combo to drop in when i can afford it all. so might stick with a stock-ish 4K and spend the money on the looks sides of things atm.
Greeeeen Beastie!!!
How'd Ben go with the crap in the clear and the bubbles?
- Upi Spotted
Towe's Turtle
hmmmm, behind the auto x member or infront??? Manuals have the X member in the forward positon, Autos are further back. So possibly not a problem limited to the 55's. Let me know though, you've got me curious now. And all Good man, just trying to help people out. We (Greenmac, JasonKE30 and myself) found out the hard way, right at the time we were ready to bolt my manual geabox in. Realised there were no holes that even remotely lined up. We Modified the auto X member with a rectangular steel plate and as i mentioned earlier, Sam Q is now in possesion of it as to make some more for this purpose. CHEERS Ryan
Slo-038 + 10Psi
Considering we never got them here I'd probably be right in saying they're rarer than K-T bellhousings (in Aus). I think i've seen 1 pic of a KE35 with a TE front in Aus. Feel free to correct where needed.
Throttle Bodies
Thanks mate :P What are they off of, if you know? CHEERS Ryan
Towe's Turtle
I had that problem with my 30. then again it was an AMI 78 model, so pretty much a 55. Best way would be to have a looksy. Manual X-members are a fair whack forwars from the auto X-member.
Throttle Bodies
Wanna sell the 32mm's?
Towe's Turtle
Lookin Good Towe. Mounts differ between auto and manual chassis. Talk to Sam Q about an adaptor mount. He has the original adaptor mount that i made. (allowed a KE70 5spd to bolt up to an Auto KE30 chassis. CHEERS Ryan
Throttle Bodies
But thats just me, I have access to most things to fabricate a manifold etc. Someone might get a workshop to make them a super titanium, gold plated manifold. then the price of the carbs would probably be the cheap part :P
What Grinds My Gears.
oh, manly gaga?
Throttle Bodies
yeh man, grab sum pvc pipe n shit. hold it all together wif knead it. the chicks will go crazy for the cheapness :y: In all seriousness, Have a look at TommyKE11's thread. He had a plate laser cut then just had runners directly to the carbs. manifold fabrication and laser cutting wouldnt cost too much. The carbs would be the most costly part of it IMO
Opinions On These Hub Caps?
I don't really think they would suit. Yes, they do look good, but IMO not on a corolla. That said, If you do put them on. I think they will be a PITA to fit to 26" rimzzzzzz when the hydraulics get fitted.
--------{Ke38 Wagon}---------
Here in SA. we have to keep well within the law. We don't have any sort of roadworthy tests. so the 5-0 are really onto the defects. Minor defect (tyres etc) go to the cop shop. one look over the problems as written on the defect papers, $25.50 and its all good to go. Major defects (height, oil leaks etc) go to Regency (Vehicle Inspection Staiton, Located in Regency Pk). WHOLE car gets a fine tooth comb check. If all good, $140 later and your all good to go. If it doesnt pass, it will be double defected and you will be sent on your way to have them both fixed.I have personally seen cars with 3 (THREE) defect stickers. Regency is also considered the last stop before the wreckers or heaven for older cars on defect.
Zze122r
Suprising how much room these things have inside. Especially in the back, plenty of leg room with a riddle shorty driving :y: Sorry Sheena *ducks for cover**
Ae71 Rollllaaa
Haha, kinda makes sense. When i seen it the massive falcon air filter was held on by duct tape :y: But he was in a rush for the cruise.
Exactly what I said a page or 2 back. Shits me. You want it, you get in contact with the seller yourself. Anyway, WGMG, People with no "people skills" namely my leading hand who has been doing the supervisors job for the past week and rest of this week. 1 moment he's all good, next he's jumpin down ya throat at the smallest thing. I wonder what his head would look like after i drop a 1m length of 75x75 angle iron it from the mezzanine :y:
Slo-038 + 10Psi
Yea, thanks Josh. I knew i'm not supposed to see the engine whilst driving :P I was planning on running a KE30 bonnet and grill. after seeing a 36 with the TE front I'm up in the air wether to import a TE grille and Bonnet. Decisions, Decisions..... Anyways, worked on the beast for a couple hours yesterday. Dropped the entire steering and suspension setup and removed and partially stripped the gearbox...Finally. Also sprayed the inner front guards to look all pretty X member, LCA's, Swaybar, Castor Rods, Castor/Swaybar mounts, Strut tops and Spring hats are in Luc's possesion to be powdercoated black. Apart from the swaybar that will be done in silver, just one of the ways I plan to lace the silver and black exterior into the black engine bay. Cleaned up the bay a little more now theres nothing in it apart from the booster Also while I'm at work I'm planning a shifter relocation setup to bring the shifter to a more preferable position. It's so far planned to position the shifter 50mm or so rearward of the KE70 position. It will look pretty stock once covered with a console and even use a stock KE shifter :y: for those who know T56's, you'll have an idea of what i have in mind. Just a much better made setup. Some info for those who don't know, KE38 and 36's are 35mm higher than KE30,35 and 55's from factory. As it stands the car has had a front end colision resulting in a new LH front section being grafted on. They replaced the mangled 38 strut with a sedan strut. Here is the difference in springs;
If I Get My 4age Twin Cam Ae82 Dynoed Can They Change Or Over Ride Any
With the GZE pistons, I wouldnt thing you'll be pulling too much power as low comp isnt the way to go for N/A. Just wait till you get the SC on.
Where To Get Good Second Hand Rims In Adelaide???
I've been in there. Looks like a big Selection to choose from. Jason KE30 got his wheels from there.
Penelope....penny The Twennnny
I assume it has a banjo style diff? As i have heard kicking both wheels is a sign its worn. Did the same in my 25 when i managed to get wheel spin.
Camera Stolen
Thats just some f@$ked up shit right there. I hope this comes back to bite them on the arse BIG TIME. Sorry about your camera man, I really hope you get it back. The amount of stuff i've sold from home and hearing this happen make me a bit uneasy. But i always bring the stuff out front, never let em come round back. -Ryan
Raven'S Ke36 Delivery Van - Sold
Lookin Shmiko Micko.
Slo-038 + 10Psi
I'm gonna install solenoids in the doors. so with the push of a button, Pop. and they're open. If its gonna be a legality issue i'll put momentary buttons at the top of the doors. Other than that, a couple buttons on the dash and possibly a 2 button RF transmitter on the key ring. Boot will have a solenoid in it, that will be apart of the Alarm/Immobiliser system.
Greeeeen Beastie!!!
The Startings of an all stainless Plenum for this beast of a thing... Unpolished at this stage but will chuck it on the lathe at work and give it a wicked shine Then parting and facing it off for sqaure ends. Get some flat stainless sheet for the end caps. Machine the 2.5" hole for the inlet in one cap. Source some 2" stainless for the runners, flare the end and weld it up. Oh, and before any welding takes place, 1 piece flange for the throttle bodies will be laser cut. (hopefully i can fine a lump of stainless that wont put me into debt for 200yrs) CHEERS Ryan
