SLO-030
Senior Member
Everything posted by SLO-030
  1. Not quite Friday. But I bought an SC12 for the 5K coming tomorrow :D
  2. SLO-030 replied to Jared's topic in SA / Adelaide
    Spotted a Willow KE20 friday, in the Southern Park lands, along a driveway about 50m in from West Tce/Goodwood Rd.
  3. SLO-030 replied to Jared's topic in SA / Adelaide
    The Ol' Failwagon never ceases to impress....yo.
  4. Upper bracket is also different. requires the KE70 one to be used with the KE70 alty
  5. Holden 202 have both Hydro and Solid lifters. Red motors use solids. Blue and Black motors use Hydraulic. The starfire is a blue 6cyl with 2 cyl lopped off, they also run Hydros.
  6. Next thing you know, you're felching with a McFlurry spoon.
  7. Matt, your blurring the lines between felching and spooning.
  8. Most bits to come friday.
  9. need moar pics Tommy
  10. Hey mate. Few things for ya. If you need new leaf springs shoot me a PM, can get them to your specs and reasonably cheap. XT130 LCA's on a KE30/55 wont make any difference, they are exactly the same. 8" wide wheel with +25 will sit the same a a 7" wide wheel. The extra inch is on the rear half of the wheel due to the 1" of positive offset. CHEERS, Ryan
  11. Either those or the frozen coke straws with the little spoon on the end. For when the going gets tough.
  12. Hahaha. gonna be good!
  13. Wont be driving for a while. Moving down near you for a few months. Just gonna pushy it to work. Save some cash, Get a bit fitter and give me some time to build the new power plant.
  14. Rego is due tomorrow. Will sit unrego'd until late nov. Keep an eye out for updates!
  15. Lookin good man!
  16. If you remove the front of the load area which is a false floor, all the mounts for wagon seats are there.
  17. I guess nobody told you about the being good at it part :P
  18. Rebush them. There is 2 different bushes. one with a 12mm bore and one with a 14mm bore. Use the 12mm bore bush. The length of the bush itself needs to be cut down to KE bush length. Fit the LCA with the Sigma balljoint. Replace balljoint would be preferable. Get a wheel alignment! Sigma LCA's have been documented to give a KE70 5deg of negative camber. KE30/55 LCA's into a KE70 have been said to give 2.5deg of negative camber. So all things being equal, a KE30/55 with Sigma LCA's shoule have around 2.5deg of negative camber.
  19. Hahaha, lovin it!
  20. Good to see Shannons pergola used for something useful other than keeping the rain off dirty nissan engines.
  21. scrapping like a BAWWWSSS
  22. Any idea on trades they take on?
  23. was like 2 bucks for 10. Exactly enough to do a ke3x/55 cluster
  24. Now repping some LED dash lights. Removed the blue filter for a white light. Loving being able to see everything clearly now :dance: Picking up a gasket kit this friday too, time to fix these damn oil leaks. :glare:
