8270 -
155
Holy cap what a difference a wheel alignment can do. Feels fantastic now.
Just bought some proper hubcentric 10mm spacers and 50mm Toyota Matrix studs. Hopefully it's a bit safer than 8mm slip ons.
Yeah, makes parking it in my garage nearly impossible, add the long doors and it's a struggle to get out.
Add a wheel alignment and I'm guessing it'll be pretty great, kinda a handful on the highway at the moment.
Decided to ses if I could service the front wheel bearings to eliminate the small wobble I have under brakes. It's too much of a bastard to do with the tools I have so I might get a mechanic to do it. While I was there I thought it would be a great idea to do the Prothane bush kit. And wow, there were some flogged out bushes. It now has brand new Castor arm bushes front and rear, control arm bushes front and rear and front sway bar bushes. Shoukd be cool to see the change tomorrow. Also noticed my front left tyre is getting scrubbed out so time for the wheel alignment I've been putting off.
New episode.
Added some 4x4 wheel arch flare along the stock lip to give it back some of that low agressiveness of the old lip. Plus its rubber so I wont smash it to bits.
Ah didn't know about the angle thing. Just seen heaps of people mount them that way, but it makes sense. I wouldn't trust the parcel shelf unless it was reinforced.
If the engine wasn't native to the chassis it needs to be engineered. No KE came with a 7k.
If you're not running rear seats attach them to the lower inside seat belt mounting points. That way with the straps angled down to the floor they will hold you down in your seat.
Next : new rear flares. Gonna make my own.
Blue Thing: The Daily / Motorkhana Hack (Now Efi)
B.L.Z.BUB replied to carbonboy's topic in Rollaclub Rides
Did yours have a speed sensor in the dash even thought it was carbied?- 539 replies
I came across this picture , kinda liked it. Just happened to find a louvre in a 2nd hand store that kinda was the same shape. This is a test fit. And seeing as the genuine dealer option ones seem to be non-existent... So one thing led to another. Made a small panel to fill between the roof and the top. WIngnut bolts into the original mounting points for the stock roof lip. Couple of brackets off the C pillar trim mounts. Done, might trim the sides a bit so its more angular. Possibly fill the lower corners. Total cost $5.
Putting Rear Coilovers In Ke70 Need Help
B.L.Z.BUB replied to george_rolla's topic in KExx Corolla Discussion
AJPS will sell you and adjustable spring/perch combo so you can retain the original setup but have adjustable height. -
Pulled off the edge of a driveway and did a boo boo. So I fixed it. Then the next day I decided to do some more improvised off roading across some pot holed shit. Stock spoiler back on, kinda prefer it.
11/10 would buy if I had the room, be a perfect daily.
Check local laws. Some are draconian when it comes to emissions. It won't affect performance in any way.
Yeah, Ive gotta pull them apart and inspect. Too Cold for cars today. And if going by the rest of the car I've had to fix I'm guessing the bearings are stock original.
Started getting a steering wobble under braking, thought I'd have a peek. Found this, unrelated to the wobble but yeah. Sway bar resting against the LCA, plus the sway bar ball joint was on a crazy angle. Not really sure how whoever installed them managed that. Wound the links up as far as I could and gained about 10mm minimum at the closest through the turning range. As for the steering wobble I think the crazy offset has flogged out the front right bearings. Theres a bit of movement up and down and also side to side and all tie rods etc seem good. I'll order a new front set and install them and all the front bushes in one go. Yay cars.
- 539 replies
Do you have the ISCV and all that crap hooked up? Or have you cut out the fat? I'm guessing as you're down south the ISCV would be worth it. I had massive idle hunt after I did the HG on the AW. Turns out I forgot to plus in the temp sensor on the thermostat housing :/ CEL standard FTW.- 539 replies
Like the holocaust. Jesus Reed, what the ʞ©$ɟ.- 539 replies
