Jono.C
    2479
    28
Everything posted by Jono.C
  1. I want it quite low yeah, I'm going to daily it around 1/2" off the tire hopefully or lower.. With gas shocks it should be alright
  2. I'm going 22mm swaybar in the front as well.. The whole thing will be stitch welded when i pull the motor out Also found some photo's of the bike carbs.. Was when i was playing with the fisheye so they're a bit sketch but i'm sure they'll suffice.. As you can see the manifold isn't finished yet but. I still need some tube to connect the carbs and then make a bracket to the rocker cover.
  3. Ended up sending my springs back in favor of 6kg. So hopefully it'll be firm but not jaw breaking
  4. What drugs do you sell?? I want this kinda money!!! Itbs look trick!
  5. Can sympathies with that..
  6. Escorts are the shitttttt.
  7. Most people use an Hsd sleeve kit because it's a metal sleeve, Not aluminum like the T3 one. Also the t3 sleeve kit doesn't weld to the strut, it sits on a perch which put me off. Just generally the HSD one is better made and quality for not much more money
  8. 'Bout time you updated Corey! Looking sweet as always Ever since i saw you widen the rear end i've wondered how neatly it could be done for a street car..
  9. Surely a 4a flywheel would be too big to for the K series bell even if you made an adaptor?
  10. Just beware those ones i posted are 4x100 offset so FWD junk, You need 4x114.3 ones
  11. 15x7 http://www.racinglab.com/rota-grid-v-002.html
  12. They look like 15x8's to me
  14. Reaaaaaaaaaaaaaaaaaaaaaaaaaaally? Vin Diesel........
  15. The seats may have come from the wreckers or another car even.. hard to say I guess
  16. Yeah for sure! Yeah there's quite a few corolla's in the build at the moment..
  17. Jono.C
    '67 Ke10
    Edit, Didn't work. Will update later.
  18. How's your parking going? chh-chhh-chhh-chhh-chhh i presume?
  19. 40ft!? What do you feed it!? :P
  20. That's probably the best bit of the whole movie haha, Either that or the 100m sprint! That's the version i have, downloaded it the otherday, got a bad-wrap for the subtitles on my version, Obviously some people don't realise you can turn them off...
  21. This would be insane as a bungee jump! The worlds first person to jump off the Aizhai Bridge in China The world’s highest and longest tunnel-to-tunnel bridge has opened to traffic in Hunan province, central China. The Aizhai suspension bridge links two tunnels 1,176 metres apart, carrying traffic 355 metres above the foot of Dehang Canyon. Construction of the bridge started in October 2007 and its main sections were completed at the end of last year. It is designed to help ease traffic in the mountainous region, where queues are common due to the narrow, steep and winding roads… http://www.youtube.com/watch?feature=player_embedded&v=IvLlviIZkkA#!
  22. For a tight twisty road such as in Touge or Hillclimbs even, there's no way in hell i'd run a weldy.. Ps, Drift is win, You're just old. ;)
  23. What do you mean.. Why would you change the height of your shocks? You want shorter extended length, and shorter stroke to hold lower springs captive if that's what you mean?
  24. No, They aren't. But they don't serve much purpose in other forms of motorsport.. Besides rally or gym/ motorkhana i guess They're horrific for tight cornering as they understeer like mad and push you through corners instead of letting you corner properly. So that's why i didn't see the point of a weldy if you don't drifty drift
  25. Doesn't this thing have a weldy though? Could be wrong but i thought i read that a while back Weldys suck unless you're trying to be Takumi Fujiwara
