Everything posted by Duckman
Engine Weight
5K's must be a fair bit lighter than 4k's for whatever reason. I bought a 5K with attached K50 last night and had no way to get them off the back of the ute other than my own two arms and back. So I pulled the gearbox off the motor whilst still in the back of the ute and lifted it out. The gearbox has bugger all weight in it so I'd say 25kg's would be a good guestimate. I was then going to seperate the head, block and manifolds etc to lighten things up so I could then heft out the rest but decided I couldn't be bothered as it was nearly 9:30PM and starting to rain again(plus apparently the sump is still full of oil...a disaster waiting to happen). As the alternator has been located on the other side to the manifolds on this engine(the 5K in Rosie, my KE30, has them all on the same side) I used them as handles and lifted the motor out. It wasn't too much trouble so I'd guess it weighing in around 100kg's? Might have been easier as I could keep the load nice and close to my body and it was distributed pretty evenly.
My Baby Ke30 :)
IF you're going to destroy something you may as well destroy it in style :y:
Slo-038 + 10Psi
Ahhhh so close. How does it feel? Actually, answer that when she's all back together ;)
- Oops
Fatty's Ke20
I know where to find welders, just not that cheap :blinks: Now all is clear :jamie:
Holden V6 Into Ke70
If you want a V6 go a VVTi 1MZ-FE. I'd definitely look at putting one in my KE30 if I could.
Holden V6 Into Ke70
Two Jay Zee? No Shit...
Holden V6 Into Ke70
http://www.v6conversions.com.au/TOYOTA%20CORONA.htm <---Turn your KE70 into a Corona first?
Car Security For Ke70
I like the high tensile steel rod to gear shift idea. Simple, old school but seemingly effective!
Fatty's Ke20
Aww man, looked like a fairly clean car too. Where did you pick up the welder from? I'm hunting around for a mig myself to tackle my car cancer.
Would You Be Interested?
That could be a very tidy alternative for the corona/pug/hilux set up with a shit load more options considering the after market support S13's have(off the shelf parts). Would make engineering a coilover/big brake set up just that little easier.
3sge Beams Blacktop Into Ke35
Be daring. Put a 1MZ-FE VVTi in her ;-)
Guess What Won Least Sexiest Car Of 09
What model Corolla are they referring to? Whilst the E39 is a fine looking vehicle I would not call it the sexiest of all time.
New To Forum, Bought A Ke25!
Nice score! Wish I had a brother like you. I like the time permitting at the end...time makes fools of us all. I have a growing pile, of jobs and parts for my rolla....time permitting they'll find their way into my Rosie(what I call my KE30) Best of luck with the resto :jamie:
- Green Switch
15x7 Wheels! Not Happy!
What about Performance Superlites? They can be had for about $250(new) per wheel I think. That's what I want for my KE30...or some nice Globe mags. Sechs.
4age-ke30 Engine Mounts
I read somewhere that the KP61 Starlet 4AGE mounts that you get from Techno Toy Tuning may work. http://www.technotoytuning.com/productdetail.php?p=785
5k Block, Which Head To Use?
Less compression = More BOOST!!!!!!!!!!!!!!
Oil Pressure Switch
Hi, Just wondering if anyone knows off of the top of their head what type o' thread the oil pressure switch on a 5K uses? Can't find my thread gauge...its not with my taps :D Thanks in advance!
For The Rally Guys
Love the music almost as much as the car :/ You guys have seen 'Climb Dance'? Now that is rally type porn!
205/60/14 Tires
So, if I find my offset is, hypothetically, -5mm and there is atleast 15mm between tyre and guard I could run up to -20mm offset wheels? NOTE: plucking figures out of the air to get my head around this
Ke20-ae86 Suspension Parts
R&P and 3/4 link rear end for a KE30 coupe would definitely grab my attention!
Ke20 Project
As far as I know we are unable to get these road registered here. A friend of mine wanted to put a hyabusa engine in his mini and the engineer he contacted said no no no no no. Have things changed, or was it a lazy engineer? We were disapointed, would be lovely to have a sub 900kg car singing at 13000rpm! Hell, it was always a thrill at upshifting at 21k rpm even though it was gutless(referring to my first bike which was a FZR250)
7ke Efi
What was the reason behind the exhaust manifold Taz_rx?
7ke Efi
