December 29, 200619 yr comment_157322 So yeah, how does it come off? Ive taken out the middle nut, what else is there that makes this thing come off? KE70 to btw. Edited December 29, 200619 yr by Shaun Report
December 29, 200619 yr comment_157324 From memory, the nut should be it.........now ya just gotta put a whole lot of muscle into it and yank & riggle the shit out of it until it comes off. Just be careful not to smack yourself in the chops :y: Report
December 29, 200619 yr comment_157325 lol, yeah loosen the nut but keep it on the thread, this way you won't nail yourself with the wheel when it comes loose. i GENTLY used a rubber mallet to persuade mine to come off but be careful, you don't want to wreck your collapsing steering column. Edited December 30, 200619 yr by JC807 Report
December 29, 200619 yr Author comment_157326 Thanks guys, i reckon i would of smacked myself knowing me, might get my pinch bar out and lever it off. Report
December 29, 200619 yr comment_157330 Wriggle from side to side whille pulling the wheel towards you! :y: Report
December 30, 200619 yr comment_157336 use a steering wheel puller kit or 2 jaw puller, both $15 to $20 ea at trade tools. i found the 2 jaw puller works well on boss kits. it takes under 5 seconds on the tightest of steering wheels and wont damage the wheel. sometimes you can get it off using a mallet, muscle or wiggle it if its not on too tight but its a fair bit of sweat and time and can damage the wheel if it is stuck. the wheel is fitted on using tapered spline and the nut forces it to jam on there when done up so it wont come off, thats why they are difficult to remove. Edited December 30, 200619 yr by styler Report
December 30, 200619 yr comment_157351 Wriggle from side to side whille pulling the wheel towards you! :y: I agree. Also helps sometimes if you get it on the steering lock and do a few gentle ones that way too. DON'T try and lever it off, you're gonna damage something for sure. Report
January 3, 200719 yr comment_157808 i did this today. i just left the nut on a little bit and wriggled the wheel from side to side while pulling it out. it came off in about 30 seconds so i guess I'm lucky. Report
January 3, 200719 yr comment_157837 get angry. hit with hammer while pulling with other hand. if angry enough, wheel will come off Report
January 3, 200719 yr comment_157844 With the nut half off, thump the wheel on either side quickly with your fists like a two year old having a tantrum (I can even lend you the two year old, complete with tantrums.) You're not thumping the back of the wheel here, but the front. This loosens the wheel and should come straight off. Never failed for me Report
January 3, 200719 yr comment_157845 ^^^^Yep allways used Redwalfs method and has never failed me.^^^^ Report
