How To Fit A W50 To A K Series Motor
Hey guys thought I might as well add to this thread with some info on fitting a W50 to a K motor.
See page 3 for installation info. :jamie:
DSC03136.jpg?t=1178082828
any body recognise that gear box bolt pattern??
Bell housing is apparently out of one of those K utes (republica).
Edited by Taz_Rx
  • Replies 79
  • Views 224.2k
Could it be a K to W bellhousing ?
ill have a t50 or 2 on sunday you can come see if it fits (asuming that you own the bellhousing)
Still in NZ, looking at buying it once I find out what GB it is for.
I'm assuming I'll have an answer by tomoz, but if I don't, you wanna check the T bolt pattern on Sunday for me?
Not really sure ,its hard to tell :jamie: :y: :fuzz:
You best be sending me one of those T50's man, :jamie:
I don't know what it`s for but definatly not a t50. They have 7 bolt holes on flange.
its a bellhousing for a steele case gearbox that came in the liteaces that had 5k's, don't ask me what the gearbox code is but the one that i saw was only a 4 speed column shift, would be bullet proof though i reckon
Hi,
Just looked in the EPC for you and all I could see was that car only got the starlet K box only so prob a K to K.
But ill have more of an in depth search later.
Cameron
if they made a k box with a removable bellhousing chances that the bolt spacing is the same as a w is posable.
