flat out Posted September 13, 2007 Report Share Posted September 13, 2007 ok well i have king springs in one of my cars and want to put them into my good road car, but they are miles too high, so what do i do? i have cut heaps of normal springs before but the gab between the springs is different, like these in this link http://cgi.ebay.com.au/NISSAN-PULSAR-KING-...1QQcmdZViewItem i know some one will flame me for cutting my springs but its the road I'm taking and i want lower stiffer springs so this is it Quote Link to comment Share on other sites More sharing options...
irokin Posted September 13, 2007 Report Share Posted September 13, 2007 Whens the funeral? I'm starting to wonder if we should be outright deleting threads like this because of the possible liability they create... As for your question. They're progressive springs and you're just going to have to experiment. Start from the small end and take off one coil at a time. Still a really dumb thing to do. Quote Link to comment Share on other sites More sharing options...
Corolla_Kid Posted September 13, 2007 Report Share Posted September 13, 2007 The "gap" is because they are progressive rate springs. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted September 13, 2007 Report Share Posted September 13, 2007 Whens the funeral?I'm starting to wonder if we should be outright deleting threads like this because of the possible liability they create... Delete. BUY SHORT STROKE SHOCKS IF YOU PLAN TO CUT THE SPRINGS OR YOU MAY DIE. END DISCLAIMER. Quote Link to comment Share on other sites More sharing options...
Des Posted September 13, 2007 Report Share Posted September 13, 2007 ok well i have king springs in one of my cars and want to put them into my good road car, but they are miles too high, so what do i do? Buy the right springs. Cut springs are fine in a bush basher but not on the road. Quote Link to comment Share on other sites More sharing options...
flat out Posted September 13, 2007 Author Report Share Posted September 13, 2007 coilovers arnt an option for me so cutties are the only answer, i might take them out and compress ither end with my hands and what evers stiffest ill cut Quote Link to comment Share on other sites More sharing options...
irokin Posted September 13, 2007 Report Share Posted September 13, 2007 coilovers arnt an option for me so cutties are the only answer, i might take them out and compress ither end with my hands and what evers stiffest ill cut So get springs made to suit your requirements. There should be no reason for anyone to cut springs! Quote Link to comment Share on other sites More sharing options...
kangaroosa Posted September 13, 2007 Report Share Posted September 13, 2007 Just sell the King Spings and put the money towards custom springs. I had a set made up for $140. They are 40mm lower than Lovells superlows and One gauge thicker wire. Quote Link to comment Share on other sites More sharing options...
flat out Posted September 13, 2007 Author Report Share Posted September 13, 2007 i could use t18 struts but then they would have to be overhauled, i have ra23 struts also but here I'm just talking about standard ke55 ones Quote Link to comment Share on other sites More sharing options...
Redwarf Posted September 13, 2007 Report Share Posted September 13, 2007 coilovers arnt an option for me so cutties are the only answer, i might take them out and compress ither end with my hands and what evers stiffest ill cut Cut springs are NOT the only answer. Don't be tight. Buy custom springs. Vote 1 for locked thread. Quote Link to comment Share on other sites More sharing options...
coln72 Posted September 13, 2007 Report Share Posted September 13, 2007 Before you lock it Red, I run cut standard springs for close to eight years without a problem. They were cut significantly. In fact the second cut was made without removing the springs :locked: as the nose sat too high after dropping the rear almost to the stops. Yes they did come off the seats when the car was fully jacked up but for them to drop out you would have to be airbourne, which is a lot braver than I was on the road. Anyway if I got it that wrong I think the springs would have been the least of my worries. If you are concerned you could wire/cable tie springs in place or just ask the tyre place to put them back for you :D. I guess one of the reasons I didn't have an issue is that with the second sway bar I was running, the travel was about two inches anyway but there still wasn't an issue when this was removed. Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted September 13, 2007 Report Share Posted September 13, 2007 Custom springs ftw. I have cutties in the back and they are no good. I had too stiiff a spring to begin with, and once I cut em they just sucked. If you want drift, you will want to stiffen the rear, traction the opposite. Beerhead on this forum, or AJPS, or many suspension shops will get custom springs made for you and not very exxy. Make sure if you do cut the rears you leave the flat bottom mating surface alone, and cut the open wound top part only. When you cut the top part its not all that different to how it looks standard, but the spring rates will be all cocked up. Are you aware that they get stiffer as you cut them? I can't speak on fronts cause I have coilys there. Quote Link to comment Share on other sites More sharing options...
Des Posted September 13, 2007 Report Share Posted September 13, 2007 I thought they get softer when you cut them ? Quote Link to comment Share on other sites More sharing options...
flat out Posted September 13, 2007 Author Report Share Posted September 13, 2007 theres less spring so it makes it harder Quote Link to comment Share on other sites More sharing options...
Redwarf Posted September 13, 2007 Report Share Posted September 13, 2007 theres less spring so it makes it harder Erm.... no. You're not really changing the rate (although you are de-tempering the spring with heat), you're changing the height. The way to make it harder is to make the spring thicker. Or something. Quote Link to comment Share on other sites More sharing options...
