Bluey's Rebuild.
  • Replies 214
  • Views 67.6k
omg my Xmas bonus was a box of chocolates...
Holey crap (excuse the pun but it had to be said) Good to see progress is being made.
and i was about to ask what the hole saw was for... did you weigh all those bits you cut out? 12kg from the body deadener seems well worth it + whatever else you cut out.
You would have to be really retentive to do that, as well as collecting all of the body deadener in a box to see what it weighs.....
I'll let you know when I have the scales downstairs again...... :y:
hahha your not the weight reduction kind untill you can meet and beat tony and chris's weight reduction - lol you seen under the dash pad for example ?
Lookin tops rob :dance:
how much does a cage for a small car like this weigh?
The one that's going in, a fair bit.
Main hoop and double cross
Front legs and x bar
Sainz bars
Rear legs and harness bar
Double side intrusions
Bars from front legs to front strut tower
Double roof bars
At a guess, around the 50-60 kg mark, but I tend to hit things hard these days.
The one I pulled out of the old car was about 40kgs.
Teddy, the dash on the 55's are different, and there isn't as much metal to remove. However all captive nuts and brackets that are no longer required are also being removed.
I know it seems silly removing all this weight and then sticking a pipe factory inside, but to me it's worth the effort to keep it as trim as possible. The cage is not just safety, but also structurally strengthening as well.
  • 2 months later...
Received car back from cage builder yesterday. Two weeks away, and there's been a bit of a change.
This is now about the minimum spec cage that I'll have in a good car.
Pics are a bit ordinary, but you get the idea.
It mounts at 8 places, the usual 6 plus through the firewall to the front towers. It's tagged to the body in a further 8 places.
Business cards can be distributed on request, although this guy does have a substancial back log. :)
Send some info this way Red :)
