Was just wondering what is the best and most effective way to get more power out of a k motor?
eg. supercharger, turbo, efi or anything else that anyone knows of.
I'll hopefully be running into some money soon so i wanted to do up my engine without doing a full blooded conversion.
so whats the ultimate upgrade?
twin charging, supercharged and turbocharged
all forged internals, completly balances and blueprinted
and some amazing drivetrain bits
and then you'l be laughing.........at yourself because you could get the same power out of a dirty nissan motor for alot less money
nah jk,
depending on how much money you want to spend thers a fews things you can do,
3k head on a 4k will give you abit of extra power, as will getting your cam reground geting and exhaust and wber or modifying the snadard carby,
everything depends on your budget and what you can do yourself
1. choose 2 out of: speed, reliabilty, cost
2. more power from stock = more undriveable (useable powerband)
3. heres my version of a k series engine power list from least to most:
3k std
4k std
5k std
7k std
warm na
hot na
race na
supercharged std internals
turbo std internals
supercharged aftermarket forged internals, efi, ecu, intercooled, boosted etc
turbo aftermarket forged internals, efi, ecu, intercooled, boosted etc
driveline and gearbox may need upgrading at hot na onwards.
might add power estimates later...
one of my mates had a ke70 with hot as NA 4k that put down 56rwkws, 4age should do this standerd :jamie:
a speedway mate said he made 3k run 69 rwkws at about 9000 rpm
Should?
They normally make almost 20kw more at the wheels.
Should?
You lose more in the drivetrain in a RWD car remember....plus a lot of 4AGEs are getting rooted these days, especially bigports. I've seen a bunch of AE82 TCs pull between 50 and 60kw at the front wheels all on the same dyno, on the same day.
