Chestikoph Sr20Det Ke55 Coupe
Almost back on the road, still not sure about the lip though.
Might look better once its all painted, and bumper is on.
post-4551-0-83086700-1360240340_thumb.jpg. post-4551-0-14449600-1360240408_thumb.jpg
  • Replies 344
  • Views 356k
  • chestikoph1
    chestikoph1
    Pretty much finished. Turned out ok, I think? Doesn't give too much away when the plates are on. Only need to do the short hose from the block to the thermostat. Thermostat fully opens at 86 degre
  • chestikoph1
    chestikoph1
    I have had to butcher up the dash in order to fit back in around the cage, the Carlos bars have made it really  hard to get it back in. It has to wedge between that and the A pillar bar for to fi
  • chestikoph1
    chestikoph1
    Have made a start on the inside of the car, ripped out the old sound deadening off the inside of the firewall and stuck on some dynamat. I want the cabin to be nice and quiet. This stuff is great, e
I vote no lip but any which way you go with it, still an awesome car. The before and after shots rocked my world.
  • 2 months later...
All back together and painted now, also tidied a few things in the engine bay as well.
I am going go withthe lip, now that its painted it looks better on.
Starting to get withdrawals, need to start driving this thing again.
I kinda liked the later bonnet more and my spare front bumper is pretty shitty, so if any one has decent
ke 30/35 bumper they want to offload send me a pm.
nice one mate
now drive this thing arm on the window styles
nice one mate
Cheers Carlos,
Will try and avoid the water barriers now!!
Could have been worse, got a pretty expensive wall hanger pwr radiator and cooler now, or $1700 of scrap aluminium.
Both of them copped the brunt.
shit mate. at least she lives to fight another day.
i prefer no lip to be honest. still a killer car on all accounts though.
Where did you get that lip from, if you don't mind me asking?
big fan of this car, good to see it has been fixed up.
  • 4 weeks later...
Was having issues with the excessive angle of the swaybar link, due to the heavy castor and camber changes.
The lower control arm was fair bit more forward and with rose joint, it was pushed about an inch wider.
That was causing the link pin to tilt rather than act on the swaybar.
So I have knocked up a bracket and changed the swaybar link to another rose joint link.
post-4551-0-78575000-1369657525_thumb.jpg.
  • 4 months later...
Been a while since the last update, and there has been a few things happening since the last one.
The sway bar links made a huge difference, so it's the way to go if your going to run big camber.
Have done a few sprint events and car is developing every time, new semi race Federal RSR tyres made a big difference as well as some decent brake pads have brought times down.
Also soon to be done is a hydro handbrake running off a second set of calipers, and going to trial a rear sway bar to see if I can enduce some slight early entry oversteer.
For the moment its the chase for some more power, installed some bigger Nismo 555cc injectors and a bigger airflow meter, so hopefully that will nett me the magic 200kw atw.
Will update after the re-tune.
I think that's about all the chassis will handle before there's an adverse reaction, it really needs to have a cage fitted,you can see the flex in the body when you corner hard, the door windows move away from the seals, and being a coupe doesn't help.
Thought about linking the front and rear chassis rails, maybe that will help reduce the twist in the shell.
Any one done this?
Only one pic for now, will upload more once I get a chance.
Here's a few shots Jack Barnes (fellow rolla owner) took at a local sprint.
The dual caliper brackets are finished, just need to source another set of rear calipers, run a another set of lines to a seperate hydraulic handbrake master cylinder.
The fluid reservoir will be remotely mounted in the engine bay.
So I will be running two sets of hand brakes, the standard cable one for parking, and the hydro for the track.
coming along nicely, you coming to toyotas in the park this year ?
