Seat Upgrades
i found this out totally by accident i picked up some ford fairlane seats from a wreakers if you swap the corolla seat runners on to the falcon seats they bolt straight in no drilling required all falcon/ fairlane seats from xa 1971 to xf 1987 share the same base defintaly a good comfort upgrade over corolla seats :(
  • Replies 55
  • Views 87.4k
i would have thought they would be too wide for a corolla? My 2002 corolla seats are almost too wide in my ke30 the inside of the seat sit on the center console.
I would have thought a falcon seat would be wider.
Edited by NickZ
sounds comfy. i like those falcon seats that come trimmed in wool from factory. i wonder if they are from that era. definately worth looking into
i have ta22 celica seats in my ke30. they bolt straight up to corolla rails with 1 hole drilled. theey are way better because u sit much much lower in the car. i am over 6 ft and have alot of clearance from the roof.
yes you will need to drill 1 hole to fit ke70 seats i think into a ke55. As for the falcon seats theres no drilling required on a ke55 anyway. I'm 6ft 3inches and i have no problems getting in and out of the car, Just don't drop any money down between the door and the seat as theres not much room left to grab it :D just swap the corolla runners onto the falcon seat and they bolt straight in. :)
That still didn't answer my question...are you saying you can unbolt corolla seats off their rails...and bolt falcon seat directly to the corolla rails without modifying ANYTHING
One of my mates who has a Falcon bolted a set of Scheel seats straight onto the stock rails in his car. If that works , then I guess that if I grabbed those seats they should bolt straight into my KE20. It sure opens up the choice of seats if they aren't too wide for the car.
Cheers, Ian
r33 gts-t, wrx, aw11 or some type of aftermarket seat will make its way into the rolla.
stewart had S13 buckets in his ke15, no idea what he did to fit them, but the guy can weld so it might have been not-bolt-in
