September 8, 201016 yr Author comment_466894 there isnt a hint of an intercooler behind the grill without it painted. I do plan to fix all the small dings and just a simple re-spray in gloss white. Might spray the wheels matt black aswell. Report
October 15, 201015 yr comment_475787 Evo engine in a rolla sounds like it could be some awesome fun. How does it drive? Report
October 15, 201015 yr comment_475796 ao with the stock xmember being used what sort of mods were required to get the engine mounted? any pics of that? Report
November 22, 201015 yr Author comment_483671 i had to take a little out of the sump to sit it lower than what it was going to be, could of got away without cutting. other than that just a case of making up mounts both block and x member. Edited November 22, 201015 yr by Jordanrolla Report
December 12, 201015 yr Author comment_487800 Brake's finally sorted and i have now had a chance to have a half decent drive of this thing with NO clunks or concerning noises coming from the car. Without a doubt or exaggeration i would have to say this is the most FUN i have ever had in a car! It is everything its supposed to be which is built to be tough as nails, quick, awsome handling and is good enough on the juice to drive everyday. To drive this thing is pure bliss, the satisfaction from building 100% of this car is a great feeling. I don't wanna sound like I'm ego tripping or nothing but f@$k I BUILD A GOOD CAR! shortened the struts last light and a vid of just a moderate acceleration. http://s238.photobucket.com/albums/ff297/Jordan1977/?action=view¤t=Picture166.mp4 Just short of a lsd installation for skid vids Edited December 12, 201015 yr by Jordanrolla Report
December 12, 201015 yr comment_487820 Sounds porn dude - great to see you've got the beast on the road - I can see the light of the tunnel on my KE now - can't wait for the joy of driving it. Report
December 12, 201015 yr comment_487828 And moved to the technical builds section. Well done mate. :rolls: Report
December 13, 201015 yr comment_487979 Doesn't even sound like a mitsu, good work. One thing I loved about working on 4g63's are those big sharp cam gears :laff: Report
December 13, 201015 yr Author comment_488015 thanks guys, feels so good to be able to pull it up in the garage and not put it on stands and fix it (or try to). I agree trev, alot of the time it doesnt even sound like a 4g63 especially in the video but in the car if you listen close enough you'd be able to pick it. I think its got alot to do with the exhaust, the way it was made. It may get changed later on. Report
December 18, 201015 yr comment_489175 Nice work mate, the sound of a 4G63 with a 20G roar is wikked, make sure to use the stock E7 ECU with EVOscan, you might be surprised how much tuning and datalogging you can get out of it, and with the super AUD is a bargain with the cable and software, My only suggestion other than the nifty engine mounts, most RWD converted 4G63 engines i have seen use an engine plate mount to the stock driver(front in your case) engine mount on the chassis rails otherwise than the massive torque these engines spit on 4WD system to a RWD is gonna be awesome Edited December 18, 201015 yr by NISROLA Report
December 24, 201015 yr comment_490396 damn i like it should do some engine mods to this extreme then it will be a handful http://forums.bimmerforums.com/forum/showthread.php?t=1575817 Report
