August 3, 200917 yr comment_363196 Hey, i have got a 5k motor in my sierra ute and it has the points type dizzy. I am wanting to put an electronic dizzy in it so can someone tell me what cars i can get an electronic dizzy that will fit into the 5k motor. I know about changing the coil over to have the ignitor and that but i just need to know what cars i can get one from so i can start to search the wreckers. Cheers Report
August 3, 200917 yr comment_363204 5k powered liteace. Not sure of model code. They have an inbuilt ignitor. Report
August 3, 200917 yr comment_363210 5k powered liteace. Not sure of model code. They have an inbuilt ignitor. KM36 :wink: Report
August 3, 200917 yr comment_363406 hey mate, i have a 4ac and i have made the change to elec dizzy, one of the best investments i ever made. personaly i really wouldnt bother with searching the wreckers, you can buy brand new ones from Crane cam. i got the Fireball XR700 and its great, you could prob pick one up on ebay for cheap along with some new leads and you should notice a differance. hope this helps. Ben Report
August 4, 200917 yr comment_363512 Crane cams have gone bust apparently and are in liquidation Report
August 4, 200917 yr comment_363566 hey mate, i have a 4ac and i have made the change to elec dizzy, one of the best investments i ever made. personaly i really wouldnt bother with searching the wreckers, you can buy brand new ones from Crane cam. i got the Fireball XR700 and its great, you could prob pick one up on ebay for cheap along with some new leads and you should notice a differance. hope this helps. Ben how much did it set you back ben? explain the basics? Evan Report
August 4, 200917 yr comment_363574 GA61XX (an absolute legend if you ask me) over on Toymods has done a guide with lots of pics on how to convert a Nippondenso 2T or 2TG, 3T-c & 18R-c to an electronic dizzy very easily using donor parts from an RA60, RA65, RT133, or '85 RT142,( Not the '86 ) dizzy. Essentially you take the coil /ignitor plus the dizzy internals and install them into your recipient engines dizzy body. See his photo here I wonder if they will fit inside a K dizzy body..... I only have one K dizzy here in my K engine which I am not inclined to strip at the moment, but if you are keen, I picked up all the parts on the weekend for only $55 at my picky wrecker (and that included a complete dizzy as I was in a hurry). Full thread is here Edited August 4, 200917 yr by parrot Report
August 4, 200917 yr comment_363611 Crane cams have gone bust apparently and are in liquidation I had a look about that, seem they are just under new ownership........ :hmm: S&S Cycle of Viola, Wisconsin acquired certain assets of Crane Cams, Inc. on May 7, 2009. Those assets include the inventory, intellectual property, and trademarks for all Crane automotive and motorcycle electronic and valve train products. The intellectual property portion includes designs, drawings, and cam profiles. Crane Cams was founded in 1953, and like S&S Cycle, founded in 1958, it has become a respected and iconic brand in the high performance industry. S&S intends to continue to sell Crane products through the same distributors and dealers who have sold them in the past. To that end, they will establish a new facility in Daytona Beach, Florida to manage the business and provide customer service and technical support. This new facility will be staffed by many of the same personnel that Crane customers have worked with in the past, providing as seamless a transition as possible. While there may be some shortages of product in the near future, the Crane/S&S team will be working hard to fill back orders and meet future demand for Crane ignitions and valve train components. It will take some time to bring Crane products back on line, so please be patient, and check back to this website frequently for up to date information. Hopefully this is correct and the parts they supply will still be available for some time yet........ Report
August 4, 200917 yr comment_363659 how much did it set you back ben? explain the basics? Evan Well to purchase the system itself I payed $170 I think? Not too sure it was a while ago now but as I said before you can pick up cheap NEW ones off eBay for a bit cheaper. As or the basics...... well I pulled the instructions out of the box had a quick glance over and said “meh i think the mechanic can do this one”. $50 latter it was done and tuned. Edited August 4, 200917 yr by Stixy Report
August 5, 200917 yr comment_363837 Just use one of these bad boys: Was EXTREMELY hard to get rare as. BUT it is an original MSD TRD system for a K motor :D there are 3 different types of ignition for a K motor TRD made. 1 was early CDI MSD system. then this later one. Then one that was for electric dizzy and used individual coil packs. This one uses points dizzy but packs way more punch and multiple sparks (manual is in jap but I can make out about 6 sparks at 8000RPM per cyclinder). And it stops arcing in the points so they hardly wear only the lobe on it so adjust grease and off again. Cheers Cameron Report
October 26, 200917 yr comment_385495 Ok OLD thread dig I Have purchased a 4k electronic dizzy External ignitor i think what do i need to connect this a ignitor and A coil but from what ? how do i wire it up and of what model cars cheers Report
October 26, 200917 yr comment_385496 Bosch GT40 coil works with most... that's the extent of my knowledge :yes: Report
October 26, 200917 yr comment_385497 i have one of those atmo i now need to know about a ignitor Report
October 26, 200917 yr comment_385499 Any ignitor will really do. They're just an earthing relay. Should have 3 wires - 1, coil negative 2, ground and 3, trigger from elec dizzy. Second wire from the dizzy just goes to the coil +. Report
