MYSTIK
Region Leader[RL]
    1140
    2
Everything posted by MYSTIK
  1. repair manual FTW :P
  2. do you have a timing light? timing should be 10 degrees at idle with the TE1 and E1 terminals bridged, without the terminals bridged it should be 16 degrees at idle. now to set the timing once the motor is at TDC you need to bridge the TE1 and E1 terminals in the diagnostics box. (paper clip/wire is fine) check the base timing it should be 10 degrees at idle if not loosen distributor blots and turn the distributor, tighten bolts and check the timing, repeat if necessary unbridge the terminals and check timing it should be 16 degrees at idle this should be done with the engine at running temperature as well
  3. http://www.rollaclub.com/board/?showtopic=21861 think its on the last post of the above link
  4. the holes arent pre-drilled, but there should be a slight depression on the firewall which should be behind the "SR" sticker. basically everything else hiro posted is spot on :lol:
  5. http://forum.pulsar.org.au/showthread.php?t=56699 the link above is what i was going to base an the SA section version. which i havent got round to doing yet as i've been quite busy. as for legal requirements well i wouldnt think there would be any, because its on the recommendation of the members who use the fourm
  6. which should be accessible via the boot
  7. sounds like a good idea Tally, so I'm assuming by older toyota's you were thinking everything toyota?
  8. not if there is 3 police cars and a paddy wagon like last fornight :P
  9. wrong suburb that's elizabeth :)
  10. PNKBTZ on a skyline, the driver seem to be a looker, but i was going in the opposite direction at good clip
  11. MYSTIK
    Spotted
    wanna do mine, while your at it?
  12. pistons, cas, map sensor,injector, loom, ecu and I/C from a 4agze, then strap a turbo on the side, run some oil and water lines, and plump in the I/C and you have yourself a relatively cheap turbo setup. thats if you rebuild or you can do a similar low boost turbo setup on a standard 4age using all of the above (minus the pistons) and have fun till it pops :P just depends on how fresh your 4age is or how cheap you want to do things anyways I'm getting way way off topic here :P Edit:rad32, i've changed the topic so that it suits the discussion
  13. on a 4afc!!! :hmm: i must have a rare 4afc then if it doesnt have a computer :P mate its a carby no computer :P Anyways now to the original poster, nothing cheap can increase the power of a 4afc, its one of is the economy twincams that toyota developed. best suggestion here would be to work on the suspension, to get it handling nicely and then do an engine swap, or once funds permit buy another ae9x with a 4age then swap over all your suspension and have the best of both worlds :y: p.s i did the suspension on my 4afc corolla, then bought a one with an 4age later on down the track and swapped 90% of my suspension over to the 4age corolla
  14. if its a place to get parts list it, but from what i recall he was banned for advertising or making a profit from rollaclub :P
  15. umm the probe was a 2 door coupe :jamie: not a four door
  16. looks like a taurus with a merc badge :jamie:
  17. i seached "importers" and got 3 pages and that was all the forums >>> http://www.rollaclub.com/board/index.php?a...hlite=importers but knowing what to use search is harder :jamie:
  18. thats what the search button @ the top of the forum is for as well :jamie: here my search of the sa section turned up(one of my own posts :) ) http://www.rollaclub.com/board/index.php?s...st&p=248999 << couple of these places do have import motors or i should say did have last time i checked. and google gave me this one as well http://www.adelaidejap.com.au/adeljap/ so all in all not very hard if people use a little time and effort, rather than posting and hoping someone will be nice enough to answer
  19. Importers, there is plenty of them in Adelaide.
  20. MYSTIK
    Spotted
    guy can you take the car specs to msn/pm, or how bout making a thread in the Rollaclub rides section :jamie:
  21. look at her profile pic its just a straight metallic red :jamie: my opinion is to leave the wipers black, black grill(although I'm pretty its already a dark colour to begin with), dump the car on its nuts and go with a slightly larger wheel in black/charcoal with a polished lip
  22. all i can say is "snap, crackle and farken splat" :jamie:
  23. 8:30? seems really early hmmm i know the cruise is getting there @ 9:30, i was just wonder for those who arent going on the cruise
  24. just for interest sake what time are people getting there?
